Best lower door inserts. Super atv vs honda genuine
Mcclain210
Mcclain210
29
53
North East, Ohio
Which lower doors are better in your guys opinion? Super atv lowers or the honda oem lowers. Im ocd about fit and finish and dont want a rattly mess. I have zero issue paying more for quality. Heard mixed reviews about honda ones so thats why im asking. Thanks.
Reactions: TxDoc
5,016
22,384
I had the SATV door lowers and liked them, 7 holes per side and 4 were dimpled from Honda so you couldn't miss drill them. There's 3/8" gap around the edges. @Lil_Steve has Honda's OEM lowers, maybe he'll comment. I know that they need to have notches cut in the door so they fit, the SATV don't.
Having said that - with the radiator up front, the cab heat in the Talon is uncomfortable for me and I'm a desert rat at heart - I'd much rather be cooking than cold. 🥶 🥶 🥶 I won't be installing lowers in the new Talon, Rokblokz keep the debris out and the open doors let 'some' of the heat out (not as much as I'd thought). I've been riding in 30* temps wearing tennis shoes and I'm still comfortable.
Super ATV, they have a slight crease to follow the body contour.
I DMCdZRG L
I 5jkjbwk L
N
nobeer142
Chippewa Falls Wisconsin
I put Tusk brand on and they come with a rubber seal that you put around the edge to help close the gap. I put black caulk around it when i was done to keep dirt and water out. It seems from what I see the gap is the same on all of them along with mounting.
Mcclain210
Mcclain210
29
53
North East, Ohio
Did you notice your foot ever bumping the door stop getting in and out of the cab with the super atv ones? Looks like it could possibly get in the way.
Reactions: TxDoc
906UP
906UP
12,981
120,950
da Yoop
I have the Honda ones on mine, they suck! It feels like its an afterthought they ways they're designed, a buddy has SuperATV on his, much better fit & finish than mine.
Mcclain210
Mcclain210
29
53
North East, Ohio
I feel like honda dropped the ball on their accessory line with some items. It seems like the super atv bumpers, lower doors and other companies are making much stronger and better products.
5,016
22,384
Yes, they seemed to be 4" x 6", always in the way and I'm not sure that they accomplished anything (maybe prevented 'flapping in the breeze' ). Note that I'm north of 70 and swinging my leg over the door sill isn't all that easy anymore.
Lil_Steve
Lil_Steve
544
2,107
Gilbert, AZ
I agree the Honda door lowers suck. For an OEM accessory the fit and finish is terrible.
PaulF
PaulF
1,462
4,810
Thanks for input! You guys made my decision pretty easy
I have the Honda lower doors and they fit perfect if you install them correctly. They look factory and do not rattle. However, they are a total pain in the A$$ to install correctly. The trick is to cut enough of the door away to make the brackets on the lower doors fit flat/flush. If you don't cut the correct amount away, they fit horrible and can stick out at the bottom.
I opted for the Honda ones because I found them cheaper than any of the aftermarket ones at the time and I am a cheap bastard ;). VERY glad I got them.
DAJO
182
125
Indiana, Arizona
I have no problem with fit or finish with my Honda door lowers. Took the time to install right and they look like they came from the factory. They still did not take that long to install just a little more attention to detail. They were the only ones available at that time.
Doogle
Doogle
186
249
Surprise,Az Cincinnati,OH
I like the "Cheap" statement. Many older people grew up with hand me downs and mom made clothes. We collected Coke bottles for the 2 cent return. Now we buy $25k machines and still try to squeeze the nickle till the buffalo poops. I'm trying to buck that trait. When my tires wear out, I've started buying new, instead of partially worn. For the newer generations: buffalos were on the face of nickles until 1938.
Dankathy
286
822
Just shoot me a PM whenever you need anything, and I'll get you the weekly code!
Dangit! Wish i had know about this when i bought the glass windshield and the rear window! Oh well, live and learn
Reactions: SuperATV
