P1000 Best way to remove the display?
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
Those that have changed out your dash display what's the easiest way to get to it? The repair manual states to remove fender and complete dash.
Reactions: Ridem32
Boomboom907
596
620
Washington
I don't understand. Aftermarket dash displays?
Or did yours poop and you just need a new OEM one?
I took my dash off before and I'm almost certain your stuck with doing the same to get that thing out of there
Sent from my Pixel XL using Tapatalk
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
I submerged the oem display once they get wet they go out. Go figure. I have new one on order. The dash don't seem to be to much of a issue it's the front finders I don't want to remove.
Boomboom907
596
620
Washington
To get the dash off you have e to take the fenders off. Which are the easiest part. its like 6 plastic rivets.
The front panel has a bunch of threaded screws under the hood, 2 on top near fenders, and a few here and there. Takes about an hour to get it off and an hour to get it back together.
The fastest way to do it is just do it. I farted around for a few hours trying to find ways to not take everything off. It was just so much easier and faster to just do the work.
Reactions: Bayouownbeer
Boomboom907
596
620
Washington
Actually I don't think you have to fully remove the fenders. Just the front retainers and 2 on the top of the door where the little triangle pieces go for the windows.... You will see what I'm talking about
Reactions: Ridem32
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
Gotcha ok thanks. When I said front finders I meant the colored front plastics. The repair manual states to remove them then the dash.
