P500 Bigger Throtle body form 36 to 44mm ?
906UP
906UP
14,237
134,905
da Yoop
Have a 2020 p500 live in colorado and wanted to know if anyone has put the p520 throttle body on the p500. Stock p500 is 36mm and the p520 is 44mm.
Interesting, when I checked the TB for the 520 it came up with the same part # (size) for the P5, P5.2 and ironically the P700. The injector is also the same between P5 & P5.2 so without increasing the pulse width (injector on time) you'll likely see no measurable difference. If you combine it with a fuel controller you may see an improvement but I'd say it would be negligible at best. Honda rates the 520 @ about 30 hp, the P5 was 28.x hp, there's just not a lot to work with.
