Any suggestions bike running hot shortly after starting the motor at idle. Bike is brand new. Radiator is full. Saw a post about burping????? any suggestions never even got a drop of mud on it yet
That'd be my 1st guess. Try running it a bit with the nose as high as possible. and see if it drops some. Just don't overheat it...Any suggestions bike running hot shortly after starting the motor at idle. Bike is brand new. Radiator is full. Saw a post about burping????? any suggestions never even got a drop of mud on it yet
yes fan came on brieflyThat'd be my 1st guess. Try running it a bit with the nose as high as possible. and see if it drops some. Just don't overheat it...
Oh...i should ask if you ever get the fan on?
Yes, Get it up on a steep incline or winch it up a tree.
Sounds like the run of the mill burp.
Please update us.
Thanks.
am was coming from the radiator fins no leaks from tankyes fan came on briefly
is this something normal that happens. it is a brand new 2016 that was sitting in a warehouse este
Yes, Air trapped inside the motor and it want pump correctly. Once fixed its all good.is this something normal that happens. it is a brand new 2016 that was sitting in a warehouse e
It's not unusual for various parts to burn of protective coatings when new. Don't recall ever seeing this for a radiator...but then again, I've never watched one. As long as you're sure it isn't leaking and is full (did you spill something on it?), i wouldn't worry about that just yet. Could be that the dealer sprayed it with some shiny sauce too.is this something normal that happens. it is a brand new 2016 that was sitting in a warehouse e
good news it burpped and burnt off the protective spray from factory no more steam thanks for the advice it helped
Fan will not operate with engine off. No need to because water pump isn't circulating coolant through the system when engine off. Probably mud or needs burp.Does anyone know if the fan will work with engine off and key on? Mine was running hot (from mud I believe will test more tomorrow or the next day) so I cut it off to let the fan cool and no fan. Comes on as soon as I start the engine. Never paid any attention to it before though.
