Well this last weekend I was going to try and modify the Bison Bumper to move the winch to the high position.
Got the cardboard template cut out. Had some trimming to do on the sides. This way they didn’t stick out like batwings.
by this time I’m liking the direction that it’s going. Removed the lower radiator guard. So the winch can mount closer to the radiator. It was going to have about 1/2 - 3/4 clearance.
Im getting so close to being done. As you can see the holes are drilled ready to go. I thought I was being very careful on placement.
Well as soon I started looking even closer. The back bolts closest to the radiator was going to hit the center cross member of the frame. I thought about dimpling the frame so the bolts would fit. Decided not to do that.
At this point I’m like okay small set back. No matter how much I tried to figure it out. Unfortunately I failed on my plan. I shouldn’t say fail. I discovered a way that didn’t work.
