P700 Brake Gremlin 2021 700-4 Deluxe
W
Woundedtatonka
12
19
Dallas, Ga
Howdy Forum Members! Has anyone found an aftermarket caliper for a Pioneer 700-4 D? Honda thinks they are gold plated. We ran into an issue with our right front caliper leaking brake fluid. 1st solution was to order a new seal kit which we installed. Refilled fluid and Bled the system. The brakes were fully functional again. My son pressed on the brakes so I could tighten the lugs. Peddle went to the floor and fluid came back out of the caliper. Back to square one. Help!
  • Haha
115,312
First off, Welcome from Michigan.
no pics of your rig yet so….
Pics Or It Didnt Happen! ;)
Have u tried to get an OEM caliper? Or is your gold plated comment meaning there expensive?
I dont think there is any aftermarket ones, and I wouldn't trust one if there were! prob Chinese junk.
Either way, u need a new one. Never liked rebuilt ones I did myself.
Neohio
Neohio
Beast of the East
14,573
73,616
Painesville Ohio
Something isn't adding up.
If you were able to successfully bleed the system, it should hold pressure when applying brakes.
How worn is the rotor? Measure and compare with minimum thickness.
Are the pads new?
W
Woundedtatonka
12
19
Dallas, Ga
Understood and agree- OEM is $350 - just seems expensive!
W
Woundedtatonka
12
19
Dallas, Ga
Are the pads new?
That’s a good thought! If the rotor became too thin- perhaps the caliper cylinder is reaching to far out? Past the seal! Pads are 50% and new ones on the way. I’ll get new rotors and try that. They are worn for sure.
W
Woundedtatonka
12
19
Dallas, Ga
Ive never seen a caliper blow a seal out.
Whats the story behind this unit.
Bought it new last year- unit has 2300 miles on it. We’ve been wearing it out on trails/some mud. I’d never seen that either! Plus, the caliper cylinder and opening were flawless to the naked eye. Put new seals in it- had pressure- worked great- was about to tighten the lugs and move on and then wammo- peddle to the floor and fluid coming out of the caliper cylinder pasty he dust seal.
Neohio
Neohio
Beast of the East
14,573
73,616
Painesville Ohio
Did you by chance nick the seal installing the piston?
Did you polish or inspect the piston for scratches?
At 50% pad life, I doubt the piston is extending out the bore.
Any chance you can upload pics?
Neohio
Neohio
Beast of the East
14,573
73,616
Painesville Ohio
Courtesy of Ron Ayers
1652454036343
Order #1, and #11.
Unless the casting is damaged, that should fix your leak 100%
I would order a new bleeder just for s***s n giggles.
W
Woundedtatonka
12
19
Dallas, Ga
Right, there prob isnt any aftermarket. I was asking how many places didnu check for the OEM?
Your dealers price may be higher than others.
I found it a bit cheaper on Adept Power sports. I've not hear of them but I'm willing to give it a shot at $295 for the whole sub assembly. The way I've been searching is to find the part # and then google it.
W
Woundedtatonka
12
19
Dallas, Ga
You don't have any idea what the mil spec on a set of new rotors is? I'd like to check mine against a stock rotor....
115,312
Whole hub, do u mean the rotor, caliper and barring assembly?
Neohio
Neohio
Beast of the East
14,573
73,616
Painesville Ohio
I am at a loss.
If you rebuilt the caliper and it leaks. Where does it leak? From the piston or the casting?
If the piston. Save yourself $200, order another main seal and a new piston. Make sure you use brake fluid as lube on the seal when installing.
W
Woundedtatonka
12
19
Dallas, Ga
