P1000 Brake light splice location
O
oilslick
105
134
central illinois
Hi all,Adding a turn signal kit and want to use factory tailights. Wondering if anyone knows where the right and left are spliced so I can seperate them. I have looked and searched threads but no luck. I will post my setup when done,just got it last Friday. Pk5
67,231
Hi.
Can't give you clear info until tonight. I'll snap a pic.
But, they both run under the bed towards the center then they combine together into one plug.
Reactions: Lady01
O
oilslick
105
134
central illinois
Hi.
Great, thanks for getting back,that sounds easy enough to find, guess I should take another look tonight.
Reactions: Lady01
67,231
Ya. Look for wires running just under the tail gate from both sides.
Reactions: Lady01
322,675
Just noticed this thread. Here's the diagram of the wiring I made doing my turn signals. You'll find the wires going across the frame rail under the box on the driver side going down below the cab. look for a green wire with a yellow tracer it starts at taillights and goes across under tailgate and should go all the way forward. It's the same at either taillight. Run test light from cab forward to be positive.
Reactions: Lady01
bowtec101
5
Kearney MO
  2. Other Brand
Does anyone know how to splice in to the brake light wire? What color is the wire trying to do it from master cylinder wiring harness?
Reactions: Lady01
67,231
Not aware of any wires on the master cylinder on NON-LE versions.
Not sure about LE versions.
But the brake light trigger is right there on the peddle assembly, It would be the green/yellow wire for brake.
bowtec101
5
Kearney MO
  2. Other Brand
Just got done hooking wire harnessed up for brake lights the green and yellow wire and the brown wire for the running lights. Neither one seems to be working. I even tried grounding the ground wire which is the green and white wire to see if that would help. Still not working. Is there something else I'm doing wrong?
Reactions: Lady01
bowtec101
5
Kearney MO
  2. Other Brand
One more thing I am using the XK glow blinker light system.
Reactions: Lady01
Worse1
Worse1
145
554
Arizona
try
Use a light tester to confirm wiring. Make sure your accessory light switch is on. That bit me in the ass when I installed my license plate light 😂
Reactions: Lady01 and ChadD
