P1000 Broken Bolt mount to A-Arm. 2018 Pioneer 1000-LE
Scoop
Scoop
5,253
20,760
  3. Talon R LV
And now I know what WOTF means thanks to the WOTF!
For old f*ckers like me, it used to be WOTL - wisdom of the list. That was back before discussion FORUMS became a (popular) thing and we pretty much did the same thing using email distribution LISTS. No threading or searching (unless you saved all your email), but it's all we had back in the 90s and early 00s. Good times, good times.
Scoop
Scoop
5,253
20,760
  3. Talon R LV
Bolt kit ordered from the Club Store and my bro is lined up to knock this out.
Too bad I didn't order the bolt kit 2 days ago when I ordered the Hillbilly Brake or @Hondasxs could have shipped them together. The latter item is delivering today. Doh!
someguy1313
someguy1313
239
519
SouthEast
Have the Bolt Kit ordered from the club store (nice kit)
Last night:
Installed a bolt on (may weld soon) in upper gusset last night and i'm not sure the two will play well with each other.
Question: is anyone using the club store bolt kit with welded or bolted in gussets?
I want these front a arm tabs and surrounding frame as strong as possible. it's probably the weakest design on this machine with the heat management a close second.
IMG 8582
ToddACimer
ToddACimer
Pioneer 1005-2
3,772
15,972
Oshkosh, Wi
Last night:
Installed a bolt (may weld soon) in upper gusset last night and i'm not sure the two will play well with each other.
I have my tabs doubled up to be thicker and I have the kit from the store with the weld washers. I also got custom made bushings and sleeves from RB3 and I'm running 12mm upper a-arms bolts instead of the stock 10.
You can see how thick the tabs are compared to stock plus the gusset into the bumper mount. Also note the bottom a-arms pivots all have gussets and welded washers
PXL 20230718 221738993
PXL 20230719 005526240
208,909
Last night:
The idiots that welded my washers in just welded the washers on without the bolts installed, thus bolts are in a bind.
ToddACimer
ToddACimer
Pioneer 1005-2
3,772
15,972
Oshkosh, Wi
I definitely recommend having both the bolt and a-arms sleeve in place for welding. They don't have to be torqued but they should be there to maintain the width of the a-arms tabs and the alignment of the holes
