P1000 Buggy Dead on Road
TAW
TAW
73
88
Texas
My 1000 keeps dieing as I’m driving and it will start up right after and drive a little ways and die again the wrench showed up with a number 2 under it does anyone know what it could be I’m at my hunting lease for my 50th Birthday and don’t want to go home if I can fix it
Reactions: Lady01
TAW
TAW
73
88
Texas
I had installed a second battery and thought maybe it wasn’t hooked up right so I un-hooked it buggy ran great got back in to hunt same thing I’ll look at the ground when I get back to camp I sure don’t want to go home took vacation days for opening weekend don’t want to spend them at the house!! Thanks for your input
the wrench with a number 2 just means time for oil change and service. Check all your ground wires
lled
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
Can you give us more details?
When did it start doing this? after you added the second battery?
Did it start doing it cold first thing in the mourning?
Any info when, where, and how it started helps on diagnostics.
Like say it only starts doing it after you ride it for a while = plugged tank vent
TAW
TAW
73
88
Texas
After the battery but I took it out and it’s sti doing it but I do ride in a lot of mudd could it have got into the tank vent
te
Reactions: Lady01
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
You don't have mud in it, but who knows what insect tried to crawl in it?
A very simple way to check it is the next time it dies take the gas cap off and put it back on and see if you can run it for a while before it acts up again.
So if I am understanding it, you can start it up when the engine is cool and run it till it warms up then it will shut off.
Reactions: Lady01 and pct
Neohio
Neohio
Beast of the East
17,824
86,022
Painesville Ohio
Do you know how to check codes?
Reactions: Lady01
TAW
TAW
73
88
Texas
We’ve figured out the fan is not coming on the gauge says it’s running cool but the bike is getting hot does anyone know how to bypass the switch to run the fan manually
Reactions: Lady01
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
Been there done that and got the pistons to prove it.
When low on water the heat gauges do not read correctly you need to raise the front end and burp the radiator also try turning the fan by hand my fan had froze up this spring (not from cold) I had to break it loose by hand and it has been working happily ever after.
TAW
TAW
73
88
Texas
That didn’t fix it it seems to be an electrical problem took it back to Honda they have another buggy doing the same thing no codes they are trying to figure out what’s going on it could take awhile. Figures it would happen at the start of deer season I’m starting to be a regular at the Honda shop not happy about it!
Reactions: Lady01
E
Elpers
Indiana
I’m having the same issue now with mine did you ever find a fix?
Reactions: Lady01
P1K5Dave
P1K5Dave
2,258
8,457
Petoskey, MI
@Elpers you dug up a 4 year old thread to ask about your current problem.
Better you create a new thread in the Pioneer 1000 Shop Talk forum, describing your issues in detail.
Pro-tip: If you can get codes from the flashing "check engine" light, it'll help us help you faster.
Reactions: Lady01
