P700 Bushing Noise - Grease it - Fix it
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Just a FYI...I have a fairly new P700-2 , 2017 model and it had a little noise in the front end. Could not notice it when riding, but at stand still you could move the steering wheel or put slight up and down pressure on the bumper and hear it..both sides. I narrowed it down to the upper control arm, the connection point toward the front of the machine on both sides. I don't think it was hurting anything, but just bothered me. I took the mounting bolt out and loaded up the inside with grease, re-installed the bolt and torqued it down to correct specs...on both sides and it fixed the noise..
Lesson : Grease up all pivot points....don't assume the factory greased up everything properly...
Reactions: Max718
Deluxe700
Deluxe700
856
1,101
Central Arkansas
You need to use a waterproof silicon based grease...NOT petroleum based grease. Petroleum will "swell" the bushings, if they are rubber....NAPA sells Sil-Glyde , but there are a lot of silicon based greases out there.
