P500 Cab Frame Cargo bag and rear panel (P520)
Aerolite
Aerolite
114
499
Oxford Mills ON
Honda accessories bag and a Tusk rear panel. Main difference on panel, other than price, is Tusk doesn't have the zippered window in it, and the Honda has three hook and loop fasteners that attach to to cross bar behind the seat back perfectly, while the Tusk has two clip fasteners that work ok. Tusk had this as a P500 accessory but fit fine. I really like the bag, all those small compartments will come in handy. Only downside is it impedes a bit of your view from the rearview mirror.
IMG 3834IMG 3836
Jlojub
Jlojub
7
30
Ontario
Where did you order the tusk rear panel from and How did it compare price wise to the Honda rear panel? Thanks
Reactions: J80
177,980
View attachment 253487View attachment 253488
Solution is to bail on that rear view mirror. I altered mine to sit further away and down more to make it usable and it still sucked. Side mirrors are the way to go, cheaper and far more useful. Once you do that, move that cargo bag to the front bar where you can access it while riding, again far more useful. FWIW
skinnyman
34
76
ohio
Will the rearview mirror work with the cargo bag moved to the front bar?
Reactions: Mudder
177,980
I don't think so, that mirror sits pretty high if I remember right. Even after modifying it to sit where I wanted it to, I only use it to carry the fuzzy dice. I use the side mirrors for everything.
Reactions: Mudder
Aerolite
Aerolite
114
499
Oxford Mills ON
I got it from Rocky Mountain Atv/mc
US$65 vs US$147 for Honda accessories.
Aerolite
Aerolite
114
499
Oxford Mills ON
I can still see out the mirror but definitely not as good as before. It’s big and I hit my helmet on it a lot too, lol. We will be riding on a lot of tight trails and I was thinking that side mirrors would be constantly getting hit by the brush. Will try it out like this for awhile and if the rear view annoys me anymore I’ll give the side ones a try. Will see how many times we go for something in the bags while riding to see if moving to the front would be better. Not sure if I want to see those or not as well. But thanks for the advice and ideas.
We have the EMP wipers on the way as well after seeing your post about them, thanks. Will be a lot easier than the squeegy we have been using, lol.
Reactions: Mudder and trigger
futzin
futzin
4,129
30,680
Kentucky
I like my Honda rear view mirror on my P5. Occasionally bump it when getting in, but otherwise no issue for me. To date, I don't wear a helmet in my P5. With my usage, side mirrors would be a near constant hassle.
I have a JBL Extreme bluetooth speaker attached to my front top bar, as well.
177,980
I was totally against side mirrors and always thought they would get ripped off or be in the way. I finally caved and installed them thinking I would probably take them off for summer. Ended up really liking them. I've occasionally hit them on something going through the tight trails and they just break away the way they're supposed to. I find them much better for backing up, much like you would in your truck you can see right down that body line. Use them a lot for plowing too, maneuvering around vehicles and such. It's rare that I even look up at the rear view, usually just to make sure the rider behind me is still there.
Aerolite
Aerolite
114
499
Oxford Mills ON
Totally agree trigger on the backing up part. As I back up a lot during plowing the side mirrors would be great to have, can’t back up well at all just using the rear view, so I’m constantly turning and looking out the back.
So far since bringing this machine home with its winch, plow, roof and windscreen, I’ve already changed the wheels and tires, added the rear fabric panel and the cargo bed, have wipers on the way, and now probably going to get the nerf Bars, A-arm skidplates and now side mirrors. Does it ever stop! Lol
NTCPrezJB
NTCPrezJB
President of #NTC
108,544
957,523
Canton, OH
So far since bringing this machine home with its winch, plow, roof and windscreen, I’ve already changed the wheels and tires, added the rear fabric panel and the cargo bed, have wipers on the way, and now probably going to get the nerf Bars, A-arm skidplates and now rear view mirrors. Does it ever stop! Lol
We lost count how many times Trigger has been done with his machine. So, my guess is it only stops when the bank account is emptied.
Y
Yankeezone
21
United states
Nice bag and panel write up. Can you give us some information on your plow set up? What is the width of your plow and what brand? Also, did you install the winch or the plow or both or neither? thank you
Reactions: Mudder
Aerolite
Aerolite
114
499
Oxford Mills ON
Thanks.
It’s a KFI 60” plow with a 4500Ib Warn winch. Both were installed at the dealer before I picked up the machine.
JCart
JCart
895
2,020
Kamloops, BC Canada.
Never look back.... just trouble back there.. heh. Full steam ahead, for the Dozer. Kay I’ve looked at the outside bags that go across the cab but are they waterproof? I’ll have to check ones for inside, do they make em with a long gun scabbed too (inside cab)? Man where I travel and it’s usually just me.... so dusty, my stuff gets just covered in it. Fact was thinking of making a tarp to cover over my bed to keep all the keerap and dust, mud dirt and sheeeit out. And in terms of mirrors, outside mirrors I’d see where they’d be handy, although lotsa trails I travel I’d be skeert, they’d get mashed off. Snow ploughing for sure they’d be handy...
Reactions: Splorin and trigger
