P500 Camso track system peermanent restrictions for HP500
hponda
I have a 2017 Hp500 thinking of putting on some camso utv 4SI tracks. There is a permanent restriction warning that shows the front hitting the frame under certain circumstances. Has anyone used these tracks on the HP500 and will they go in tree feet of lose snow.
solrus
solrus
1,629
2,511
Montana
Ordered , will let u know.
Reactions: lee
P
pappyo
597
2,400
Have them on 2018 P500 --- T4S Tracks - Cab & Heat.
Cab is almost a Must :: SXS with tracks Will cover you with Snow rater quickly without a Cab.( learned that rather quick 1st. set on 09 Polaris RZR )
Both Honda P500 & P700 Handled 24/ 30in. fresh snow : slower /works harder & heavier on fuel.
Sleds are the same in that respect just faster.
In the past : had tracks on 2014 Honda P700 Cab & Heat
2009 RZR 800 Cab & Heat
I.M.O. the ability to change gears & hold that gear when needed is a Big Advantage .
Top speed on tires is cut about 50 percent ( 40mph now equals 20mph ) tracks are simular to running 60in tires ( turned with 475cc.)
Reactions: solrus
solrus
solrus
1,629
2,511
Montana
Hopefully to get them before end of Feb. Excited. My speed in argo was 5 mph but unstoppable:)
Sent from my SM-G986U using Tapatalk
