Can I put my atv plow on my sxs
Pioneer Mark
Pioneer Mark
29
67
Windber PA
I have a Denali 50” plow I had on my Honda rancher 420 can I put that on my ‘23 pioneer 1000
I’m looking at these sxs plows and the arms look much shorter I have the bracket and it looks just like the sxs bracket for the pioneer
If not can I just buy the arm’s or whatever there called I’ll get a picture of the plow and bracket when I get home
I’d hate to spend $800 if I don’t have to
IMG 3007
906UP
906UP
14,234
134,867
da Yoop
Short answer..... NO
Long answer..... it could be done if you have the fabrication equipment, welder, saws, etc. You'd be pretty much building brackets from scratch and you still have a plow thats 12"+ narrower than your track width. ATV plow mounts are usually from the center of the machine, UTV plow mounts are generally much further fwd.
66,813
Let me look at this tonight. But I too think it is a no without making your own pushtube.
Also, I can save you 10% on a new one if you are interested.
66,813
I recommend the Pro 72. The 66 will work but at full tilt, it only pushes 60 inches and your 62 as it sits.
If you don have a lot, the 72 standard should work great as well.
LINK --> SnowPlow's
DISCOUNT CODE --> SNOWMAGEDDON
Vikes79
Vikes79
SKOL!
11,684
113,328
South Dakota
  2. Talon X4 LV
72” is the best. At full turn you still cover the track width of the P1k5.
Here is what the 72” pro looks like on a ‘18 p1k5.
I purchased mine in ‘19. Still works great…last year was by far the most I used it. I have the hydro turn on mine….worth every penny…especially since the missus does some plowing with it too.
IMG 3067
IMG 5162
