Can someone with 26” or 27” tires measure to the bottom of the bracket near the reese hitch to the ground and tell me what it is. Mine with the stock tires is 9”. Just wonder because with my roof on it might be a little tight getting in the garage.
My 2017 is 9-5/16" to bottom of hitch receiver with 26x9 Blackwater Evo's but Evo's do run small, my 26" are about 24-5/8" at 7 PSI -
Since overall height is an issue for you , as it was for me and my trailer, overall height to top of EMP roof (which adds about 1/2" above roll cage) is 71-11/16".
Also, I think Honda lowered ground clearance starting with the 2017 units by close to an inch.
You can also lower tire pressure to give more vertical clearance if needed.
Good luck on tire choice
