Not on a stock machine.can you adjust the front camber on a p-700? It is stock?
I added shocks and 1.5” spacers and it looks like the top of the tires are bowed out. At a loss!Not on a stock machine.I don’t have problems with that on mine. Is there something else going on? Maybe optical illusion?
I misread that. I’ll wait for your pics to try and help some more.I do not have a lift. The 1.5 “ spacers are on my wheels. The only lift is due to the new shocks.
Maybe others with a lift will step up as I don’t have a lift. But maybe possibly the lift is installed incorrectly. @Backwoods , you have a lift, right? What do you think here?![]()
No I don't have a lift , thought about spring spacers one time but I am happy with stock height.Maybe others with a lift will step up as I don’t have a lift. But maybe possibly the lift is installed incorrectly. @Backwoods , you have a lift, right? What do you think here?![]()
Thanks for straightening me out.No I don't have a lift , thought about spring spacers one time but I am happy with stock height.
are you going to stay stock or lift ? I know you ride a lot of mud.Thanks for straightening me out.
I plan to stay stock. If I do a shock upgrade, I’m going Fox. But you had a very good suggestion on the preload of the op.are you going to stay stock or lift ? I know you ride a lot of mud.
What shocks did you put on?Staying Stock. I bought this used I only added the shocks. The only other thing I’d like to do is change the tires. I mostly trail ride. Thinking about the Terrabites.
