P500 capsule gathering of 3 green wires...?
rocmar
rocmar
4,741
5,776
4 CORNERS
Was cleaning air filter /box...
noticed 2 wire protected elec taped
together...elec tape..flappin...
went to wrap more tape...around
Then...seen a speck of green..
....this is wat I found....traced back..
...to here..on frame..next to battery box
...had no idea..they were there....
Did you?
20170522 101829
20170522 101843
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
Did you?
View attachment 44265 View attachment 44266
I found the same plug by the airbox yesterday, doing the same as you. The ground point I found the week or so before, when I finally wired in my winch. I terminated the winch there vs on the battery.
Reactions: rocmar
Deleted member 3748
I noticed those capsules too. I have no idea what they are. I looked for it on the wiring diagram too but didn't see it.
Reactions: rocmar
luckymike
luckymike
144
322
michigan
Seen those on my 17.somewhat of a novice to wiring (managed to do the winch with all the great info here).can I tap into one of those when I go to do lights and stereo?
rocmar
rocmar
4,741
5,776
4 CORNERS
I saw them too. Looks like a light bulb. What the hell could they do
It's grnd wires for...extras..
it's in that capsule to protect
...phone company..uses similar
...concept...to prevent corosion
Deleted member 3748
I always make a new ground when wiring accessories. The frame is a ground and you can use that. I cleaned the paint off a spot of the frame and bolted on a buss bar. I run all of my grounds to that bar.
rocmar
rocmar
4,741
5,776
4 CORNERS
Yes..did the same..
except for stereo & amp...
they are grounded..to frame
66,870
Its just a junction point for wire combination.
I think there is 3 or more on the 500's.
2 are straight up grounds. Green wires.
The other I think is positive. Black with red stripe. Forgot where it was.
Reactions: Eltobgi and rocmar
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
Besides the green plug by the air cleaner housing, I see another plug that has a brown w/white stripe wire going to it. It is about 3" away from the green, closer to the housing. I'm looking at the wiring diagram, but haven't figured it out yet.
rocmar
rocmar
4,741
5,776
4 CORNERS
I've seen them too, just fancy crimps to join wires.
It's a sealed capsule..with like
jell....die electrical grease...water proof...
rocmar
rocmar
4,741
5,776
4 CORNERS
Looked twice...nothing shown..or
mentioned..
Deleted member 3748
I see a Br/W coming from the PCM and three going to the upshift selector, another going to the TP sensor, and the shift spindle angle sensor... aka don't play with it. :)
