P1000 Catalytic converter removal with pics and videos
solrus
solrus
1,629
2,511
Montana
In continuation of the previous threads , I decided to post some videos and pics and how to make your P1000 cooler
Cat decapitation -
DIY explanation -
Cat vs not cat muffler sound -
20210615 202537 20210616 163736
208,730
Cat decapitation -
DIY explanation -
View attachment 279105 View attachment 279106
Did you do a before and after header temperature reading, thats were most of the front seat heat comes? from?
BigOL3
BigOL3
2,994
8,920
Cat decapitation -
DIY explanation -
Not having any first hand experience with removing cats, I surely wish there were a few more details (verbal, pics, videos, measurements) on each step ....... i.e. making the first cut and each additional cut, and more detailed explanations.
CGD
CGD
64
266
53
SE Missouri
I watched the video and removed my cat last Friday before an evening ride. The cutting and welding was far easier for me than removing the muffler and heat Shields. Even with penetrating oil, the exhaust bolts were very difficult to break loose because I had forgotten my longer ratchet wrenches and only had a deep well 12mm socket that didn't fit the passenger side bolt very well ,due to the curve in the exhaust ,and a 12mm wrench that didn't give much leverage.
Liberal doses of penetrating oil and profanity were the right combination to break them loose and get everything back together just in time for riding. The exhaust sounds slightly deeper and it definitely made a difference in the amount of heat that I felt coming up between the front of the bed and the front seats. We didn't have a rear passenger this weekend but I think they will notice the difference when they ride with us again. Sorry that I didn't take any pics but the video pretty much shows everything that you need.
Robobrainiac
Robobrainiac
2,566
9,012
Do you need the interior pipe that replaces the converter or were you trying to keep the original design by using the pipe to replace the converter?
Robobrainiac
Robobrainiac
2,566
9,012
Some pictures to add to the thread.
I would recommend reading all the way thru before attempting your own modification.
Remove the muffler.
Remove all muffler covers and shields.
Cut this section around the neck.
20230705 112917
Use persuasive force tapping on the sides of the flange. Alternate repeatedly until the neck separates.
Polish 20230705 134933092
This is what will come out.
20230705 112928
Cut again seperating the catalytic converter from the flange.
Polish 20230705 135232987
Clean the edges of the cut.
20230705 112937
These are the two adapters I used to make my internal pipe.
20230706 172315 20230706 172326
I used a bur bit to clean the edge of the metal lip on the neck piece.
20230706 172408
The 2 1/8" connector fits very snug inside the neck. It required a slight tap to seat it. Then weld around the edge of it.
20230706 172640
I used the small end of the 2 1/4", 2 1/2" adapter to slide over the 2 1/8" connector. I made it the same length as the catalytic converter used to be. Then weld the seem on it.
20230706 173348
Slide the neck back into the muffler. It is a snug fit and required a little tapping. Line everything up and then weld it together.
20230706 174604
If I were to do it over again. I would have cut slightly to the left 1/4" per the picture (closer towards the neck). I would have cut on the area just where the neck starts to taper down in size. I would cut the catalytic converter in the same spot I did. If I had done it in that manner I would have had more of an internal edge to weld the internal pipe to. It would have given me some extra room for my welding abilities.
Polish 20230706 192333136
NorthernJoe
NorthernJoe
372
1,412
Northern Ontario
Remove the muffler.
Didn't you find it was fairly easy once you got into?
I made my first cut closer to the factory weld and the cat just below the factory weld. This allows you to press the internal pipe onto the "cat" pipe and tack it into place, this way when you weld the shell back together you have backing to stop the burn through. May not be necessary if your welding skills are better than mine
Robobrainiac
Robobrainiac
2,566
9,012
Yes, it went smooth after cutting into it. I have not reassembled it yet. I stopped at autozone on my way home after work and found 2 adapters that might work. I am still thinking contemplating my reassembly. I may stop at O'Reilly tomorrow to see if they have anything different before I start to reassemble it.
bumperm
bumperm
1,908
6,791
Gardnerville, NV
Is the exhaust tubing, that most seem to be welding in place of the cat, 2.5 inches? If so, 304 stainless is available on Amazon for $29. Think I rather weld stainless than galvanized. And lastly, is that pipe necessary?
tubing
Reactions: TxDoc and JenElio
Robobrainiac
Robobrainiac
2,566
9,012
tubing
Here is my thoughts on it
Inside the neck of the muffler the catalytic converter is set inside of a neck that directs exhaust into the muffler. If you forego the pipe and weld the neck back in place you could create turbulence in the exhaust rather than directing the exhaust as the OE muffler was designed to do.
Does that make sense?
I should have my pipe pieces today at some point. If all goes according to my mental plan it will aid in my inability to weld.
20230706 073223
Neck side of the catalytic converter.
Inlet
20230706 073053
Muffler side of the catalytic converter. The end that seats into the muffler.
Outlet
20230706 073029
Reactions: JenElio and EMAW
GovtMule
GovtMule
17,564
164,077
Tennessee
Would option 2 be to just gut the Cat (nomo) and put it back as it was? Shouldn’t be too hard to just knock it out and reweld.
Reactions: JenElio
NorthernJoe
NorthernJoe
372
1,412
Northern Ontario
Inlet
Outlet
I agree with your assessment about keeping smooth flow,
keeping the "interior" pipe should help with keeping things cooler?
I used a 2.5"od exhaust pipe, it slides over the cut off cat pipe and into the exhaust can. Keep the reassembled length the same as it was. I clamped the exhaust flange to my welding table and used a framing square to get things lined up. Someone here suggested taking a zip disk and making slits at the cat end of your replacement pipe to be able to tack it in place. once you start it goes together as easy as it came apart.
Hope this helps
