P500 Check Engine Light
A
Allison1101
Pennsylvania
Just recently changed the air filter and now the check engine light is on and won't allow the machine to run for more than a few minutes.
Russ989
Russ989
22,642
147,257
It wasn’t doing it before changing your air filter?
Russ989
Russ989
22,642
147,257
Nope. It was fine.
So without asking 100 questions, I’m going to take a stab at this. Your new filter may be over oiled and not letting you P500 breath. Put your other filter back in a see what happens.
Todd627
Todd627
56,720
619,275
MI
^^^agreed^^^
43,057
@Allison1101 did you oil the filter, or was this a new one from Honda? The new ones from Honda are most definitely NOT over oiled.
I've installed them pretty much soaked and never had an issue, but...seems like quite a coincidence.
HondaTech
If its shutting off there must be a problem that's current and not a store code.
Its should flash the code when it dies.
A
Allison1101
Pennsylvania
Just tried. Didnt work. Thank you.
