Chopping the cage
pct
pct
Lost in the hills
790
1,023
Letart WV
Hope this helps it is not hard but you will need some help
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,157
Cullman, AL
  2. Other Brand
Sit in the seat and measure from the top of your head to the roof. If you ever need to wear a helmet figure that in and if you have any taller passengers. I think its good to leave at least 4-5" of clearance above your head.
320,749
Those are the same numbers I came up with Snuff
Justin21
Justin21
56
57
Jacksonville, Fl
Nope that was explained well enough for me to understand. Makes perfect since. Thanks again. I'm sure this isn't the end of my questions lol. But good for now. Once again thank you for your time. I'll definitely post some pictures when it is done.
Sent from my SM-N920V using Tapatalk
320,749
You had better lol
StephenP1k
Phoenix
Hi guys
I’m about to chop my P1K cage and was wondering if anybody can give me the rough measurements for the A.B. and C. pillar and top of the cage as well as the locations
thanks
103,925
Here's mine I think post 68 it starts. It explains why I did the amounts I did. Definitely can go more or less I'm just over 6ft and there is still plenty of room. Also if you more on front it dumps the water from factory roof and keeps sun from your eyes. It's worked out well
P1000 - 4 big changes this weekend
Just remember you're alienating all the tall people in your life. I was constantly banging my head in @CumminsPusher 's ride. Ye Dang Wee Folk messing up things again....
320,749
Ya but it had a speaker bar across the front. I could cut another inch or two now and you’d be fine. That bar will be no longer!
Reactions: Mudwing and 100Acre
Hi guys
thanks
How much do you want to chop?
How tall are you?
I’m 6’ and 4.5” for all 6 posts seems great. @ohanacreek is taller and it wouldn’t work for him.
You must add a piece between A and B. I think it was 1.5” ??
FYI, You can cut the OEM tip out windshield.
Reactions: CumminsPusher
320,749
How tall are you?
I cut a pillar 1” lower then b and c. That worked great to kill off the lake in roof and gave a little better protection against sun glare.
Reactions: joeymt33
How tall are you?
6’2” and I can just barely ride in joeys, I hate to flop or roll I’d crack my head like an egg.
Haven’t chopped mine since 2” just doesn’t seem worth the trouble.
Reactions: joeymt33
