Something to keep in mind when installing circuit breakers and fuses. In most applications, they are intended to protect wiring in case of shorts etc. Thus they should be located as close to the power source (battery in this case) as practicable. Size will typically be 35% to 50% more than the expected load, but in no case should be more that the current rating of the wire size it's intended to protect.
If there's a wiring short to ground, the fuse blows before the wire starts a fire. The wire leading from the battery to the fuse or circuit breaker is unprotected, thus should be as short as reasonably possible, well protected by insulation, and not subject to abrasion etc.
