Club GMRS privacy codes
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
I've searched the forums and found the club channel list but I have not found if we are using any privacy codes (CTCSS or DCS). Can anyone point me to the information or are they not being used?
If you buy one of Rugged radio's GRMS radios they have channels pre set with codes.
Example of what the screen will read
1-10
1-25
Etc
the -10 and -25 signal the code that is being used the -10 stands for the tenth code or 94.8 and the -25 is for the 25th code.
not a bad way to program the radios so that you have a Channel/Freq that is open and then one that is coded, but your buddies have to have same. Usually not needed as there are enough channels to switch to. However you go to a big event and you will find those channels a bit more crowded.
