P700 Club store back up light harness 2021 Pioneer 700
hadleycat
45
66
Metamora MI
I ran 1 positive and 1 negative wire from my light to the 1 positive and 1 negative wire on the harness. Then plugged harness in to the to the female on the chassis above the passenger side rear tire. Light is not working. I am missing something here?
Reactions: TripleB
66,813
Check to make sure you didn't bend a pin when inserting it.
If no.
Then check the ACC fuse up front. 15a I think.
If the ACC fuse is good.
Check the cigarette lighter socket to see if it works.
If the fuse and cig work.
Then break out a test light for the backup wires.
Report back.
