Clunking in drivetrain on tight turns
Boundertom
164
579
AZ
Hey guys, I haven't been riding for a few months, for a variety of reasons. I just got my Talon out to move it to my other shop to service it. We are heading to Hurricane next week. I drove it around our community, and noticed a pretty loud clunking when making tight turns. The switch is in 2wd. I tried backing up then forward. No change. I got onto some dirt and it didn't do it. All is fine going straight.
Coming on the forum to ask for advice was my first thought. I have about a week to get this sorted out. I appreciate any suggestions!
Tom
Boundertom
164
579
AZ
I should have included more info. My sig line seems to be gone. It is a 2021 R. I bought it new. It now has 4800 miles. Probably 30% on pavement. This is definitely something it hasn't done before. I just wiggled each end of each axle. No play or minimal play at any location. I tack welded the caps on the front driveshaft at less than 1000 miles. It is a little like a vehicle in 4wd on pavement, but no noticeable jerking/ lurching. Just the clunking.
Thanks!
Tom
hondabob
1,261
5,004
Prescott Valley, AZ
Both of my talons do it until a good warmup. My 2019 Talon has over 37,000 miles and both rear axles are still ok. I think the aftermarket axles also have the annoying clicking problem.
Dankathy
296
843
Seems odd that it would have failed while in storage, maybe needs used a bit to redistribute the grease.
Reactions: Remington
Boundertom
164
579
AZ
Exactly!!! I am having a hard time getting past the fact that it was fine when I last drove it, some 4 months ago. Since then it has just been moved around a few times. I checked all of the fluids, they were fine, as expected. Then I took it out on the highway for a few miles. at up to 60 mph. After that, the clunking was gone. The next day, I drove it again. The clunking was back, but seeming not as severe. And it went away quicker. So, I will proceed with changing the fluids, as planned, then take it out for a ride in the dirt. I suspect at this point, that it will be fine.
I think the moral of this little story is that Talons don't like to sit around! They want and need to be driven!
Tom
5,425
24,913
My inner LR boot started spitting grease just about the same time the clunking started (I actually thought it was the RR). Since the LR boot was spitting grease, I decided to replace that CV and boot (at 8157 miles). That stopped the clunking, YAY. 😎
Since I ride solo most of the time, I'm not sure how long I'd have put up with the clunking before getting nervous but the boot spitting out its grease was a no brainer, time to replace both. HondaBob has had clunking CVs for quite a while and they seem to quit once warmed up. Are ya feelin' lucky? Well, are ya, punk?
PaulF disassembled one of his and found several burned spots on the hardened steel parts and thought Honda dropped the ball on quality control - why some of us are having trouble and others aren't.
If you decide to replace the noisy one, Russel does a youtube video on how-to - it's linked below.
Since I've done one, I'd be glad to answer any questions Russel misses. I did my how-to in the What Did You Do to Your Talon Today thread.
Russel's video is also linked here -
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
Tom
Mine is doing the same once grease warms up in the axle it quits. It just started out the blue as well. Sounds sounds like it swaps sides to what ever side I’m turning. It’s not a loud click but surly different that normal. 2019 1500 miles
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
Tom
Ride or Die!
  • Love
Reactions: CID and Boundertom
Teebow
Teebow
282
1,192
Kentucky
  1. Talon X4
Had same noise on mine and would have sworn it was in the drivetrain underneath me, wound up being rear wheel bearing… sounds travel I guess.
Reactions: Bayouownbeer
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
Mine can very well be as well. Thanks for bringing that up.
