P500 Clutch adjustment success
T
twodog
Ozark Mountains
Lately my 2017 P500 was sort of sluggish shifting into 4th and 5th gears. Got almost 700 miles on it. Yesterday on a ride I noticed it seemed to be doing the same thing in lower gears. Having read the threads here on clutch adjustment I knew it was time to get the tools out and see if I had learned anything on this forum. So I just followed the directions another thread and watched the video and in just a few minutes the P500 shifts better than new. Piece of cake to get it done.
This is a great forum!
Fordman
Fordman
160
272
Fayette Al
Thanks for your info , seems when I’m kinda lugging down a logging road & hit 4th or 5th mines sorta slipping , I may need to adjust?
Rustneversleeps
Rustneversleeps
302
582
Talon,New Brunswick,Canada
did mine.... it had kind of a delay in shifting ,hard to explain but was like you shift and would bog down for like 1 second in between shifts like a late reaction...
anyways did the clutch setting according to specs and shifts right on time..
Todd627
Todd627
56,720
619,275
MI
Adjusted clutch tonight and went for a ride. Shifts WAY better now. :D
T
twodog
Ozark Mountains
My 2015 with 750 miles is doing this too. Clutch adjustment added to my list of things to do now. :cool:
You need to just do it. It really is not that hard. The only tip I can offer is to use a real short slot blade screwdriver. A regular length was hard for me to get into position. I got a short one 3 inches? and it was easy. Got maybe 60 miles on mine since the adjustment and it shifts better than ever.
I posted a reply and when done saw you had done the adjustment. :)
Reactions: Todd627
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
Guess it's my turn now! Rambo's got 1350 miles on the odometer and there is a very noticeable delay in each shift, especially in gears 3-5. It goes like this: pull paddle......wait for it...bang and the next gear arrives hard. I've never adjusted the clutch so I guess it's TIME. I'll do it this week and let ya'll know. Hoping for the same miraculous results you all got.
Reactions: Mudder
Mudder
Mudder
NTC Ambassador of Walls
11,656
88,019
It doesn’t take a lot of turning of the screw, a little at a time between test rides did it for me. Too much caused it to die out on shifts, an oh crap moment.
