Coalmont TN Ride June 21-22
Please choose your dates
  • 7-8
    Votes: 4 36.4%
  • 14-15
    Votes: 0 0.0%
  • 21-22
    Votes: 6 54.5%
  • 28-29
    Votes: 6 54.5%
  • Total voters
    11
  • Poll closed .
Ok one of them ,but good radio?
I liked the radio, I just bought something different because they came out with one that has a little bit more power.
Reactions: sharp, JTW and BWAF
BWAF
BWAF
I get paid to pass gas
8,869
42,496
Carthage MO
I'd like find on I can just plug in to my stereo
Reactions: sharp
That’s what I’m using right now. I got my ideas from NBomar and it works really good. It’s quite expensive as the hook ups are more than the radio
Reactions: sharp and BWAF
BWAF
BWAF
8,869
42,496
Carthage MO
Thought that's who started that ! Just dont know how it would work, have 4 speakers straight out of radio, then amp to sub ?
Reactions: sharp
I’ll gather up all the details soon and put it in my build thread.
Landman
Landman
The Great Bearded One
594
2,410
Central Arkansas
Thanks I'll see if will work with my setup
You're using a full head unit and amp via RCA cables, right? If so, you can use this aux-rca interface here - there's an image that shows how it connects. It ties into the RCA between the head unit and the amp. It cuts the music when the 2way receives a signal and stays silent for about 3 seconds afterwards, then the music kicks back in - it will not cut the music when you transmit.
This is the setup I'm using... the only issue is it only works with one pair of RCA cables. If you're running a pair of RCA for a sub, it will not be muted. I found an amp that has two RCA in and one RCA out... used a short RCA jumper to run back into the second RCA in for the sub line.
If you're using a bluetooth speaker bar, you'd use this aux-3.5mm interface (pretty sure this is what @nbomar has). And if you're using a head unit straight to speakers, you can use this cbm-u4 interface.
BWAF
BWAF
8,869
42,496
Carthage MO
May use last one have 4 speakers up front wired to head unit sub is RCA
Reactions: Landman and sharp
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Making sure i remember how to use this thing...gotta have coffee out in the wild!
20190608 094600
