P1000m5 Confused about tire size
Redmist
Redmist
42
41
Looking to up grade my stock tires. Wanting a taller tire without lifting the Honda. Standard tire widths are 9" on front and 11" on rear. I was looking at Blackwater EVOS at Rocky Mountain ATV and the only size they have for 12" rims is 28-10-12. Can you put the same width on front and rear? Are do I need to look at a different tire?
Any suggestion on other opitions for a taller tire without lifting the Honda (28" or 29")?
That would be a great upgrade for a pioneer with no lift kit. You can put the 28 x 10 tires at all four corners.
I'm not sure how they would look on the OEM wheels though. The front wheels are narrow and the rear wheels are wider. Maybe someone can chime in that has put 10 inch wide tires on OEM wheels
You may want to consider buying some wheels because you will be able to get the correct width. And, if you're buying wheels you could get 14 inch and open up the tire sizes that are available.
perry
perry
191
168
South Dakota
I would like to know i looked a a pix on the web site he put 28 10 or 9 all the way around but he said the were 30 inch tall and he had no problem i will go look for it and be back.
Reactions: rtn001
perry
perry
191
168
South Dakota
this was the email he sent.
STI Chicane 28x7x14 all the same size, the size is a bit misleading as they are a full 3inches taller than the stock tires, which are supposed to be 27 but are not. They do not rub, but I did need to trim the full skid plates added
Reactions: rtn001
Redmist
Redmist
42
41
Looks like a great tire also, may have to up grade to 14" wheel, what width would work witth these? Maybe I should have bought the deluxe.
Reactions: rtn001
perry
perry
191
168
South Dakota
same lug pattern, and there some threads out there that people are selling the tire and rims look around.
Reactions: rtn001
I think he was saying that the 28 inch tires were 3 inches taller than stock tires. Not 30 inches overall.
Reactions: rtn001
Most people use a 5-2 wheel and then a 1 inch wheel spacer in the back. The rear track width is narrower than the front so if you use the same size all the way around, you'll want a 1 inch wheel spacer in the back.
I used STI HD 5–2. They were just under $100 each at Rocky Mountain ATV. Plus they are bead locks.
ghost
ghost
993
1,873
BC
Thats the tire I have and love them.
Evos 28-10-12 on STI HD 12x7 5+2
I'm running them at 10 psi - no rubbing. When I installed them I pumped them up to 20 to get any stretching out of the way and they rubbed - so this is about max size to fit without lift.
I like the ride but its true about having fewer choices in the 12 inch - If I ever want to changes things. Big IF...
IMG 2751
educ8tedguess
educ8tedguess
403
972
Spring Grove Illinois
  1. Looking to buy
I am running 28 inch blackwater evos on the stock deluxe rim at 10psi.I kept the 9 inch width in the front and 11 in the rear. I like them a lot for trail riding on dirt. Unfortunately, a lot of places I ride have a lot of road riding and/or hard pack. At low speeds on those surfaces there is a pretty good shudder; especially when stopping. But, they are tough and have pulled me through some slop with no issues.
Redmist
Redmist
42
41
I like that combo of tire and wheel, If I buy new it sounds like 14" would be the ticket. Did you have to put any spacers when using this setup?
The STI Chicane is another tire that sounds good.
Reactions: rtn001
ghost
ghost
993
1,873
BC
Yeah - I currently have 1 inch on the front and 2 inch on the back.
That was meant to be an experiment - and then try just 1 inch on the back. The current setup feel so good, I have done the switch yet.
The extra inch spacer i have adds stress to the wheel bearings.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I'm surprised to hear that yours ride rough on the road. My 30's ride really well, just that roar at low speeds. Btw last Thursday we proved that the 28 and 30" Evos were practically the same size overall height. Granted my 30s only had 8lbs of air but that's where they ride the best.
Reactions: rtn001 and joeymt33
educ8tedguess
educ8tedguess
403
972
  1. Looking to buy
The ride when cruising along is fine, it's just when driving slow and coming to a stop. But in the dirt, rocks, and light mud, they are awesome and smooth. Really, you can't go wrong with these tires
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I couldn't agree more. I've surpassed their limits in the mud but for an all around tire they are awesome
Reactions: rtn001
Redmist
Redmist
42
41
i like your set up, did you have to add any spacers?
Reactions: rtn001
Bradmc87
Bradmc87
24
34
Conehatta, Mississippi
I'm also wanting 28" tires without lifting. I'm gonna go with the 28" swamp lite tires which should fit with no problem. Only problem is they only sell the 9" and 11" wide tires for the 14" stock wheels. I'd like to go 11" wide all the way around without having to buy aftermarket wheels, but just don't think they would fit on the front stock wheels. What if I bought two rear wheels and put them on the front you guys think 11" wide would fit on the front with no issues? Has this been done before, stock rear deluxe wheels all the way around?
Reactions: rtn001
Interesting thought, I'm not sure if it would work or not. It wouldn't be too hard for you to try. I'm sure it would get around the trails pretty good with 11 inch wide tires all the way around.
Reactions: rtn001
Redmist
Redmist
42
41
Deja vu...
Check posts 11 and 12
Whoops
Are the spacers need to push tire out 1" for clearance? You stated "The extra inch spacer i have adds stress to the wheel bearings", are you revering to the 2" spacers or any spacers?
On your wheel, does 5-2 indicate the offset? Looked for spacers but did not find any for Honda, what did you use?
Reactions: rtn001
