Coolant drain
Joedolittle98
Joedolittle98
16
25
Illinois
I am draining and refilling my coolant since it’s boiled over this last week, I have been told there is a drain bolt but am having a hard time finding it. Anybody care to share where it’s at before I start pulling hoses to drain. Much appreciated 2017 1000-3
Reactions: JenElio
Joedolittle98
Joedolittle98
16
25
Illinois
Found them.. I must be blind or was looking too hard. Thanks a million.
Reactions: JenElio
JenElio
JenElio
73,339
667,237
Loxahatchee, florida
If ya dont mind, keep me posted on how it goes :rolleyes: I have to do the same here soon. I got about 50/50 in it now from adding so much water to it.
JenElio
JenElio
73,339
667,237
I thought 50/50 is what you wanted to have??
I meant 50/50 cause this past weekend it spit out so much of the coolent it came with I had to add a lot water mid trail while burping it. Looks like it still has plenty of "original" coolent but I'd like to flush out the system regardless. A few local shops have told me to go ahead and put "ICE" coolent in it. They all swear by it 🤷‍♂️
Reactions: BigOL3
Joedolittle98
Joedolittle98
16
25
Illinois
Mine is all water at the moment😂😬 I boiled over several times in Hatfield and McCoy this last week because I didn’t know that the ecm flash had to do with leaving the key on accessory longer than five seconds and then starting causes the fan to not come on, and we never got it burped all the way I don’t believe.
Joedolittle98
Joedolittle98
16
25
Illinois
Also instead of ice or Honda original I grabbed the antifreeze at Napa that is for “Asian vehicles” no silicates in it and a hell of a lot cheaper than buying the Honda stuff.
  • Haha
Reactions: JenElio
Cobber4082
128
555
Solon Iowa
Wow seems there are several of us in the same predicament right now. In Silverton this week riding and boil every downhill trail. Seems to do ok until we stop or go back down. Clear full of mountain stream water right now and gonna read up on bleed procedure as what I been doing ain't getting it! Ugh tired of getting a face full of steam/coolant 😀
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
A few of us are planning a trip to Hatfield and McCoy really soon. How was the trails ?
Reactions: JenElio
Joedolittle98
Joedolittle98
16
25
Illinois
they are a blast, we rode blue and green trails as some of the guys we rode with rolled their buggy’s on the black ones before I got there. We are planning to go back next fall. We rode all of bear wallow, about 1/3 of rock house and started on devil anse before my buggy started its overheating issues, luckily it was the last two days before it started overheating. I would definitely recommend bringing tools and all the good stuff with you on the trails. Most of it is hills and switchbacks as you can imagine but they do level out and are pretty flat sometimes. Lots of cool history to check out too.
2A497A6B ABDF 4559 8C4E 363E323A9239
Joedolittle98
Joedolittle98
16
25
Illinois
Draining wasn’t bad I undid the drain plugs from the hardline under the machine, you can get to them through the skid plate. I turned the machine on and let it warm up to make sure I got most of it out. I then filled it up at the radiator and reservoir. I tried lifting the front end and burping from there but didn’t seem to get it all by the time I ran out of antifreeze. Today I topped off the radiator and reservoir and then cracked the bleeder screw until I got a solid stream then threaded it back in and tightened. With the radiator cap off I started it and let it run for 5 minutes and let it come up to two bars and revved it a bit. Topped off the radiator and checked the reservoir and took it down the road. So far so good.
FE1BC25C 0B11 4600 8010 8C5F6AD0A06C
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
Hopefully you got all of the air out of it. Got any pics of your rides, sayings around here, no pics it didnt happen 🤣
Reactions: Mudwing
Joedolittle98
Joedolittle98
16
25
Illinois
I hope I did😂 I’m sick of fighting this thing, I’ll know for sure when I get into what little hills we have around my area in south central Illinois, nothing like WV that’s for sure😂😂
7C37B1D9 D61C 4B04 AF00 552E13678C17 BC51DD46 AA74 4683 84A1 CD6C78ECEF34 D091810B C5C7 4951 9B71 BBFE3A4D8BAE AD0EAD0A AC77 4231 BB37 3DA9CC7EB7EA
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
nitzo
nitzo
521
1,105
East Coast, Florida
+1
Reactions: JenElio
Tramguage1
Tramguage1
Texan
7,478
30,587
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
M8ne
Worked better with Colorado spring water than Honda 50/50!!!🤣
