Hi Guys, Well the wife took the 520 up the mountain to feed the eagles, -4 here but Probably -10 where she turned. She stopped at the house shifted to reverse and it stalled. She said it took a lot of cranking but finally started up the mountain ( thank god ) Now it will crank fine but no start, disply stays lit even with key in pocket? I disconnected ignition switch but lights stayed on, so not switch? I can't hear the fuel pump prime, should you be able to hear it? finally can I swap out the pump relay with the lights relay to test it? oh yah, 600 miles on her. Any other ideas are welcome. TIA and sorry for the long post
