Cummins Built Not Bought/The Life of Frankie.
Coeus
Coeus
Major General
72,695
671,474
Signal Mountain, TN
  2. Talon R4 LV
And here are a couple trim panels that never existed. Not perfect but look pretty good. Trim for the center doors, another missing link completed. I now have everything to make this 4-door a ‘93 LE. Wonder what they’d be worth over on the Cummins site?
Well gotta get the rest of the cab ready to install these. Busy day and I’m working on a bit of a hangover but still trying.
Looks great in the pictures!
322,767
New power lock door latches showed up today, factory Dodge stuff. Was surprised to hear they were still available so ordered them up. Mine worked good but new is great. So new strikers and latches for the front doors. with new handles all the way around should be nice. Down to the little things.
Did locate and ordered up strikers for the rear doors but latches aren’t available. They work fine though, probably didn’t get used much being rear doors. I will pull and clean up though.
05079595 F887 487B 96D2 A7D7BE77AD15
322,767
Excellent job, I know it's easy saying this since I'm not involved but you seem to be a lot closer to the finish than the start!
I can see the finish line, first time since I started. I know you’ve done cars and know where I’m at. Lotta details left
but the big crap done. Big deal after paint is done this weekend!
J80
J80
36,867
362,201
WNC
I’m eating popcorn 🍿 just waiting with anticipation of what’s it’s going to look like when it’s all said and done I can’t wait
You have done one hell of a job on it CP
322,767
Figured quick update. Yesterday the new front door seals finally showed up so they are in. Was able to finish the front section of trim in the truck. Trim all done.
cab is ready for carpet and seats. Also sound deadener on the floor. Done for a bit on that.
C4CB7F4B 64D5 4C8F A2C0 1627C9613480
Mopower58
Mopower58
Unburdened by what has been!
82,549
724,725
Crystal Springs,Ms.
Looking good!
Fatsquatch
Fatsquatch
Approved Member
118,134
988,432
Hidden
I'm liking the rear window crank. It definitely completes an old truck look for me. You should make that part of the final design.
322,767
Need speaks bad here on a minute as door panels and carpet soon. Deck is in and wired to the doors and wiring for sub is ready. Gotta have some beats. Right now only thing I have with good tunes is the Pioneer
Trying to ease up on dollars falling out my ass so didn’t go with Infinity/Rockford Fosgate like I normally do, real bummer but whatever. Plus Infinity didn’t make the 5x7 in a component speaker combo that I want to correctly mount the doors without modifications to the door panels (still trying for that mostly stock look)
After a lot of searching and looking at reviews I pulled the trigger on Rockville 4 5x7” component speaks and 4 1.2” tweets on passive crossovers. Also added a 10” Rockville powered bass tube with remote for simplicity and size under the rear seat. They should make it by install time.
Will update on quality and durability. If not happy I’ll do something else down the road but $190 for everything can’t be too expensive of a mistake.
FFA78625 0DDC 4A03 817F EA21B4621A9C
322,767
Ok so I screwed up. Sub was 1” shy of going behind the rear seat. Did a bunch of measurements other night without seat in the truck, I was off.
b**** getting the seat into the truck through the skinny tent (poor people problems lol) but got her in to make sure and she was off. this isn’t seat going in but it was the one that came out with correct brackets.
C118E7C2 9FDF 4CF3 A10C 428BC1DB7AA0
so I’m waiting for seller response and hoping they have the Rockville 10” slim instead. Hate screwing up but I hope caught in time.
2E64342F 7077 4AE1 BE76 D3B136FD6383
322,767
Talk about last minute. Just got brakes and power steering bled out. First gen I’ve always struggled with but borrowed a reverse bleeder and got it done quickly this time.
Power steering was a b****, broke my jack and had to man handle the steering wheel back and forth for about 5 min till air burped.
she is completely a driver now, all systems go. Button a couple things up, double check a few bolts, clean up and move my tools and all my crap then she hits the road.
Guess I’m driving to work Friday with no doors, taillights, bed loose and on a bucket for a seat but she’s going!!
322,767
Railroad ties are more stable than buckets during high speed maneuvers .... according to a friend.
I’ve heard they work too. After some consideration I figure I’ll use my big ass cooler but make sure no empties in it because my chances of being pulled over are much higher then a a BLM and Biden sticker on the back of a Prius in N. Idaho.
