![Coeus](/data/avatars/m/22/22310.jpg?1719262920)
Coeus
Major General
Less pay, more stress!! Wise move.. 🤣🤣I miss this s***. I’m good at it, and like busting ass for a living. Makes me ponder why i moved up into professional adult babysitting. I mean management.
Looking good! Good luck today and can’t wait to see the progressMade paint. Got bodywork to the roof done, sucked to have to repaint but the tent collapse screwed it up. Primed both, baked then sanded. Sealed, used PPG Didge white urethane single stage then 2 coats of DC 4000 PPG clear over it.
Including work it’s been an 18hr day with probably a couple more on the way, I’m the hell out of here!
View attachment 263163View attachment 263162
Everything is moving forward! Looking good and keep up the good work!!!!Got the flares glassed ground then reglassed both inner and outer they’ll hold. Onto metal work while the dry. Welding a few holes in top rail and found some bad bodywork
Looking good Dave ,you can dooo iitAlso straightened out the box sides so gate fits good. This setup worked awesome! New gate lines up well and shuts one handed after adjustments.
How’d you make it stay straight and square?!?Also straightened out the box sides so gate fits good. This setup worked awesome! New gate lines up well and shuts one handed after adjustments.
Overpull just a bit then tap on inner panel, it’ll release tension. Broke a weld bet welded it back up.How’d you make it stay straight and square?!?
might work on @Jelewis80
Front of the bed.Looking good! Where do you keep the rail road tie?
White and greyWish I was there to offer some help buddy. I am good at the destruction part and scraping rust etc. maybe paint it like the Muppet bus. What’s your final color gonna be? White like the cab?
It uses computer for cruise control only. Nothing in vehicle usage. Yes buddy it’s completely EMP proof.Kickass on the fenders! It just needs a zombie plow! Are there any computer chips in it at all?
I barked um pretty good. Maybe after the clutch wears in😉It’s gonna be so sweet!! Are we going to see those singles go up in smoke?
