P1000 Custom Roll Cage
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
  • CONTACT US
  • ORDER
  • ACTIVITY
  • CLEAR ALL
    SYSTEM OF MEASUREMENT
    INCH
    THREAD SIZE
    3/8"-16
    1/2"-13
    THREAD TYPE
    UNC
    ADJUSTABILITY
    View attachment 157738 RIGID
    MOUNT TYPE
    View attachment 157739 THREADED STUD
    BASE DIAMETER
    2 3/16"
    OVERALL HEIGHT
    3 5/16"
    BASE SHAPE
    ROUND
    STUD MATERIAL
    STEEL
    BASE MATERIAL
    RUBBER
    DEFLECTION @ CAPACITY
    0.2" OR GREATER
    VIEW CATALOG PAGE
    FORWARD
    PRINT
    HOW CAN WE IMPROVE?
    8 PRODUCTS
    ABOUT VIBRATION-DAMPING MOUNTS
    MORE
    ABOUT LEVELING MOUNTS
    MORE
    EXTREME-FORCE VIBRATION-DAMPING LEVELING MOUNTS WITH THREADED STUD
    HIGHER DEFLECTION RATINGS TRANSLATE TO GREATER VIBRATION AND SHOCK ISOLATION THAN OUR OTHER VIBRATION-DAMPING LEVELING MOUNTS. THESE MOUNTS HAVE A RUBBER BASE THAT GRIPS THE FLOOR FOR STABILITY AND IS RESISTANT TO OIL AND GREASE. IN ADDITION TO LEVELING, MOUNTS RAISE EQUIPMENT OFF THE FLOOR FOR EASIER CLEANING AND INSPECTION.
    FOR TECHNICAL DRAWINGS AND 3-D MODELS, CLICK ON A PART NUMBER.
    THREAD
    SIZE THREAD
    LG. CAPACITY PER
    MOUNT, LBS. DEFLECTION
    @ CAPACITY BASE
    DIA. BASE
    HT. OVERALL
    HT. HARDNESS HARDNESS
    RATING TEMPERATURE
    RANGE, °F EACH
    RUBBER WITH ZINC-PLATED STEEL STUD AND STEEL INSERT
    3/8"-16 2 1/2" 35 0.25" 2 3/16" 13/16" 3 5/16" DUROMETER 30A SOFT -20° TO 180° 60855K72 $6.08
    3/8"-16 2 1/2" 65 0.25" 2 3/16" 13/16" 3 5/16" DUROMETER 50A MEDIUM -20° TO 180° 60855K74 6.08
    3/8"-16 2 1/2" 130 0.25" 2 3/16" 13/16" 3 5/16" DUROMETER 70A HARD -20° TO 180° 60855K76 6.08
    1/2"-13 2 1/2" 40 0.2" 2 3/16" 13/16" 3 5/16" DUROMETER 30A SOFT -20° TO 180° 60855K51 7.65
    1/2"-13 2 1/2" 80 0.2" 2 3/16" 13/16" 3 5/16" DUROMETER 50A MEDIUM -20° TO 180° 60855K52 7.65
    1/2"-13 2 1/2" 180 0.2" 2 3/16" 13/16" 3 5/16" DUROMETER 70A HARD -20° TO 180° 60855K53 7.65
    1/2"-13 2 1/2" 300 0.2" 2 3/16" 13/16" 3 5/16" DUROMETER 50A MEDIUM -20° TO 180° 60855K54 7.65
    1/2"-13 2 1/2" 600 0.2" 2 3/16" 13/16" 3 5/16" DUROMETER 70A HARD -20° TO 180° 60855K55 7.65
That looks good
