P1000m5 Cutting off while driving
Mark in Northern Iowa
486
2,162
Floyd County, Iowa
kramnella.wixsite.com
Howdy and welcome from northern Iowa
As stated already, search bar above is very good, IF you use the right search terms.
So, try different wordings to find what you need. If it's happening to your Honda, somebody on here already had it happen to them, now you just need to find it.
And, more information will help us help you.
How long have you had your Honda?
Does it do it all the time, or only when hot?
Is it the original battery? Have you tested your battery?
Did someone swamp it?
Does it totally shut the engine off, or does it just loose all power down to an idle?
At what speed RPM does it do it?
Do you have any flashing dash codes?
Mothers maiden name, and your bank account number? haha
Have a good day
P1K5Dave
P1K5Dave
2,244
8,419
Petoskey, MI
If it shuts down, then starts right back up the most common issue is the injector wires. Your dash will flash you a code 12 or 13 (one long blink, 2 or 3 short blinks) if it's an injector wire.
You can buy replacements here on the site store.
Be sure to report back on what you find!
Russ989
Russ989
22,642
147,257
This was the issue on my 19 as well.
P1K5Dave
P1K5Dave
2,244
8,419
Petoskey, MI
My '18 did it. It would start right back up like nothing happened. Seemed like when it got warmer, it happened more frequently.
I just replaced both while I was in there.
Still bugs me that Honda has let this go all these years. Still seeing it on the new models!
