P500 Dash Lights On Won’t Start
bms
bms
68
138
Pa
OK, so my son and I hooked up my plow. The P500 started, warmed up, and ran as normal. When I pulled it out of the garage and dropped the winch down on the driveway to double check that everything was set up correctly, and turned it off, the dash lights stayed on the check engine light is flashing and it will now not turn over. I have my battery tender on now.
Any ideas?
bigbore
bigbore
218
269
It might be in gear. It won't start if it's in gear.
Reactions: J80
bms
bms
68
138
Pa
Unhooked and reconnected the battery after the tender was on until charged - no dice. Just clicks. Someone one FB mentioned checking a switch with springs on it??? I’m not a mechanic, so I’m not sure on next steps. I have a buddy coming over later today to help me look things over.
All this 2 days before a major snowstorm - I suppose no plowing for me.
bms
bms
68
138
Pa
Thanks - I always put it in neutral and put the brake on when I turn off the machine, which I did before it died. Also, my son and I pushed it out of my driveway and it rolled easily so I assume it’s in neutral.
Reactions: SILVER_ALERT
bms
bms
68
138
Pa
Well, one of my buddies came over today after work. The battery was ok, so we tapped the starter with a hammer and it started right up. So, sounds like I need a starter.
Any particular brand I should look at or avoid? The Honda starters are $$$!
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
3,132
21,389
Route 66 Oklahoma
I like Estwing hammers, but a Stanley or even a cheap Harbor Freight should do it for you. ;)
Sorry, the devil made me write that.🤘
JollyJoker
JollyJoker
92
192
Minnesota
The starter problem is pretty common. You will find that some of the magnets in the starter housing have let loose and jam up the armature. I replaced mine with a $45 ebay one and it worked just as good as the original Honda starter until I sold it. This still does not explain the dash light staying on and the engine light on the dash going off?
500oneer
500oneer
15,000 mile club
424
1,080
Central PA
bms
bms
68
138
Pa
I bought a neutron starter from rocky mountain atv. They have one now for $45. My starter was sounding like a dental drill for a while. I did the old ignore it and hope it goes away and it worked,but did order one from rocky mountain when it came back in stock.
Yep, just ordered the same one.
T
Tstover
141
398
Central PA
Mine sounded the same, 2 of the magnets had come loose. I ordered a replacement from Ebay that worked fine until the seal failed allowing it to fill with oil. I tore the replacement starter apart and put the Honda guts in the replacement starter housing. So far all is well.
