P1000 Dies while going down the road
WagginTail
WagginTail
1,656
6,075
SC
You mentioned you put in a new battery not long ago. Check all your grounds
PJon
PJon
800
3,242
Arizona
I'm going to try and wiggle the wires and see if I can get the condition to happen again.
I’m not sure if you will get a code if the machine is starved for fuel. If anyone else knows chime in. In the meantime check your vent line from the fuel tank to see of it is plugged. If you don’t see anything obvious, unscrew the fuel cap a turn or so and see if it still cuts out.
0860silverado
964
1,862
louisiana
Also... even though you replaced the battery not long ago, be sure your terminals are clean and tight.
Reactions: Lady01
The Hunter
The Hunter
79
444
53
Kentucky
You might have a ground issue somewhere on your rig. There are post related to ground problems here on the forum, try a search and I hope you the best of luck.
P1K5Dave
P1K5Dave
2,336
8,717
Petoskey, MI
I don't turn off the key and it doesn't blink. All the lights are off when I come to a complete stop and still have the key on.
So you had a random shutdown again to check this? If so, and you got no codes, that would rule out the injectors. Ground /connection issues as suggested may be your best course.
sek-hunter
sek-hunter
317
617
Same trouble with my 18 LE. Wire broke inside the connector on the injector wire. Code 13….
I was able to get the terminal end out of the connector and reattach it.
I meant to buy two kits from the club store to permanently fix this problem. Need to do that.
Reactions: Lady01
Recurveman
14
27
Gilbert Arizona
Took the buggy for a ride this weekend and it happened again. This time I just sat there and stared at the dash. Then I got 1 long light and two short lights. That gave me the opportunity to take apart my buggy and look at items I haven't seen before. Ordered two harnesses and will fix it before next weekend.
Thanks for all the help everyone. Couldn't have done it without you guys!!!!!!
PJon
PJon
800
3,242
Arizona
Glad you found the culprit.
PJon
PJon
800
3,242
Arizona
Drove my buddy like I stole it for about 250 miles this weekend.........Problem free. Thanks for all the help guys. I think we found the problem!!!!!
Glad you cured the problem.
Reactions: Lady01
