I am having an issue with my main battery volt gauge burning out after approximately 10 minutes or so of use. The exact same type of gauge is used for the aux battery. Before the gauge goes out the brightness of the gauge goes super bright briefly. Between the switch that toggles from main to aux battery and this gauge is the only wire that I tapped into on the white/black ignition source of the factory wiring.
I am wondering if you have a diode recommendation to resolve this issue or maybe a different way to wire this up that I am not seeing?
Here is the wiring diagram
And this is the gauge
