P1000 Diode question
RockRain
RockRain
48
101
UT
I am having an issue with my main battery volt gauge burning out after approximately 10 minutes or so of use. The exact same type of gauge is used for the aux battery. Before the gauge goes out the brightness of the gauge goes super bright briefly. Between the switch that toggles from main to aux battery and this gauge is the only wire that I tapped into on the white/black ignition source of the factory wiring.
I am wondering if you have a diode recommendation to resolve this issue or maybe a different way to wire this up that I am not seeing?
Here is the wiring diagram
20180906 212649
And this is the gauge
Download
Reactions: BWAF
Have you tried switching the gauges? No reason yours should be doing that unless the gauge is bad. The only other suggestion I have is jump right off the accessory wire off the cig/ac power plug behind the dash. I dunno... doesn’t make much sense to me.
RockRain
RockRain
48
101
UT
I thought the gauge was faulty as well so they warrantied the first one. The second one had the identical results. Since I have no problem with the gauge for the aux I assumed it is feeding voltage through it and came to the conclusion that maybe I should try a diode on the ignition wire but didn't know what diode to use for sure. Doesn't make sense to me either. Also when the gauge goes brighter the voltage is still somewhat steady like the aux one so it doesn't seem to be a spike in voltage. That is kinda why I suspect it needs to keep voltage going one way. I dunno?
Reactions: BWAF
Diode won’t help if there is a load of some sort drawing power through the meter. Diode is like an electric check valve it won’t let power backflow through it. The meter should get power from battery only.
Reactions: BWAF
7,145
27,194
Just move the + wire to the main battery + post.
Add a relay that energizes with an ignition key on hot wire. Then break the common ground wire to the 2 meters. That way both meters are off when key is off.
RockRain
RockRain
48
101
UT
So I tore into it today to see if I could see a problem with the way I thought i wired it and how it was actually wired. I am guessing I wired this portion in the wee hours of the morning.
20180908 165204
The red connector is for my battery switch. I had terminal 5 tied to the aux gauge so when you toggled between ignition power or aux power it would power that gauge with either one respectively. In addition I had ignition voltage from the key powering the main gauge. So I think what happened is I had the switch toggled to ignition so it was feeding ignition voltage to the aux gauge but it also would turn on my aux battery feed to the same gauge at the same time and nuke it.
I fixed all of that but prior to figuring this out I had installed the inkbird and filled in the hole where the gauge used to be.
20180908 140406
Anyone have recommendations on a different volt gauge or should I stick with the same round one and put it next to the existing one?
Reactions: BWAF and JTW
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Here's the one I use after some of the leds went out on 1st one I had this one has less glare too
Check this out at Amazon.com
YonHan Quick Charge 3.0 Dual USB Charger Socket, Waterproof Aluminum Power Outlet Fast Charge LED Voltmeter & Wire Fuse DIY Kit 12V/24V Car Boat Marine ATV Bus Truck https://www.amazon.com/dp/B07FXH5ZZK/?tag=sxsweb24-20
