P1000 Do I need a second battery?
IdahoPioneer
IdahoPioneer
244
600
Emmett, Idaho
So I've seen that a lot of you are opting for a dual battery setup. I haven't quite figured out why. Is the stock battery really that weak? I will say right off the bat mine seemed a bit sluggish starting. I'll know more when I get it back.
Also I plan to install about 25 amps in accessories. Rarely running everything at the same time. Would this be enough to drain the stock battery?
I'd like to hear opinions and reasons behind the investment into the dual battery setup.
You will be able to use your winch for very long with the stock battery.
If you don't run the radio or lights for a very long with the key off then you should be fine.
Reactions: CumminsPusher
One other thing, you could carry one of those lithium jump packs just in case your vehicle ever died.
I carry one of these and I have used several times on a Kubota diesel tractor. It works very good.
I'm actually considering removing my dual battery set up and putting one battery under the seat to lower the center of gravity since I always carry this jump Pack. It would also get some weight off the front of my vehicle as it is already nose heavy
IdahoPioneer
IdahoPioneer
244
600
Emmett, Idaho
Wow I hadn't looked into those in years. They're so small and cheap! That will definitely put my mind at ease. Thanks.
Ordered a Optima Yellow and mount just a few hours ago to do just that. Price for all the bits and pieces for two batteries, was about the same as one big one located lower.
IdahoPioneer
IdahoPioneer
244
600
Emmett, Idaho
So you can run all your accessories as long as you want and not worry about a dead start battery.....
As long as you have it hooked up right.
Well I don't really use anything without the engine running so it looks like I'm probably ok.
Reactions: sharp
70,279
I run 2 light bars, soundbar. Winch and reverse lights. While plowing running the Winch. Sometimes a couple of hrs. Stock battery. I'll hook it up the trickle charger and it's full green in 15 min.
IdahoPioneer
IdahoPioneer
244
600
Emmett, Idaho
Thanks that adds confidence.
Again, the dual battery set up with an isolator gives you a peace of mind when your hours from camp knowing that you're not drain you're starting battery.
It will also make your winch pull a lot harder because you'll have less voltage drop and you'll be able to use your winch for longer durations.
If those two things are important for you, then I would suggest carrying a lithium jump pack and not worry about it.
Do you neeeeed to??? No. but are any of doing this s*** because we neeeeeed to????? :rolleyes:
I feel like I do, I drained the factory battery on my 700 winching, so bad it would not hold a charge.
It's a "starting" battery, yellowtop is a deep cycle. Once I had my yellowtop not only was the three times the energy storage. I could drain that storage more and not worry about it.
Winching hard draws upwards of 200amps
Alternator on 700 put out around 35 amps, there's a deficit there.
All the lights on, on my 700 overdraw the electrical system. The yellowtop "buffered"that.
I used a come a long as a kid... we didn't have winches. And school was up hill both ways!!
Bayouownbeer
Bayouownbeer
798
1,123
Chauvin LA
Honda dealer is saying that low voltage will cause clutch to slip and damage it. Like say you use your winch and drain battery down or have a lot of assories running at night.
IdahoPioneer
IdahoPioneer
244
600
Emmett, Idaho
How is that possible?
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I never leave home without my jumpbox (unlike my chainsaw lol). It also has an air compressor which might come in handy. I may upgrade to a bigger battery under the seat as Joey suggested.
Jediwrathchild
Jediwrathchild
212
410
Kodiak, AK
I'm in process of finishing my dual battery setup. Have had a couple of occasions when winching hard and the machine will shut off. Would rather not get stuck somewhere with a dead battery for a relatively cheap and simple mod...
Reactions: JTW
