P500 DO YOU HAVE TO REMOVE GAS TANK TO REPLACE FUEL PUMP
13,407
65,657
According to the service manual, all you have to remove is the seat frame. I don't know how complicated or involved that process is.
Reactions: rtn001
13,407
65,657
Doesn't look too horrible.
Capture111
Capture112
Buggyman
Buggyman
34,643
295,801
ne. ohio
Oh Lord please someone tell me I don't have to remove the gas tank to replace the fuel pump in a p500🙏
sorry I can't answer your question on a 500, the 700 is accessible from under the seat . I am sure one of these gurus will chime in later and give you all the details, there are some very helpful people on the forum.
Reactions: rtn001 and Mudwing
Buggyman
Buggyman
34,643
295,801
ne. ohio
looks about the same as the 700 not bad as long as you don't have a full cab.
Buggyman
Buggyman
34,643
295,801
ne. ohio
m
my float is hanging up so I will be doing it in the spring.
Reactions: rtn001
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,769
183,148
Grand Junction, CO
See Attachment.
  • Fuel Pump Right Side Cover Removal.pdf
Reactions: rtn001
157,872
Just a heads up, I've found those door bolts to be a pita! Doesn't seem like any allen wrench fits them right. I've had them off twice and swore I wouldn't take them off again the last time. There's also a couple of push pins for the side panel on the backside down by the bottom of the gas tank that were somewhat of a b**** to get to. Don't really understand why you would need to remove either one if the fuel pump is on top of the tank though? 🤨
Reactions: rtn001 and Duckhunt
Duckhunt
X2. If you have to remove door might be good idea just get new bolts. Mine I was able to turn with vice grip after stripping allen out and drilling bolt head off. Used anti-seize on install!
Reactions: rtn001 and trigger
Steve00
Steve00
64
91
Florida
The fuel pump is under a bar, Think I'd have to just remove the bar then remove pump
Capture2
Reactions: rtn001 and 70Bones
