P500 dobeck AFR+
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
well dobeck doesnt not keep the p5 afr stocked ready to ship they are built to order ( understanding) so its supose to ship on thursday lol so i jumped the gun here a bit and will have to wait until next week for wright up and review
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
just talked to them they said it will come base programmed for the stage 1 ( intake and exhaust) but i will have to fine tune for my riding ill prob shoot for 14 cruising and 12.5 wot
Reactions: knuckledeep
Nascar
Nascar
Cariboo, Canada
Would be interesting to know if the Dobeck AFR+ will stop the de-fuel on tranny shifts, specially in the 2017 in A/T mode. I noticed right away that you can really hear the de-fuel pop on shifts in A/T, not so much in M/T mode. Reminds me of a buddy’s friends Mercedes AMG on full throttle 7000+rpm shifts, as it too de-fuels and you can really hear the turbo bark/pop off during shifts. My Fatboy Harley used to do the same pop on hard/high rpm shifts until I installed a Arlen Ness power commander and it adds a smidge of fuel at shifts and the pop went away.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
i can tell you that when i added the hmf exhaust with dobeck ejk to my rancher it shifted so much faster with ZERO bog between shifts so i would imagine it would be the same they are pretty much same motor tranny everything
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
im sure its a combo of breathing better and more fuel but it shift fast you can hear it here.
Reactions: trigger
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
well afr is installed and took for just a quick ride and it pulls much much harder through the rpms!!!! i have a few more things to do before i button her up and fine tune it but install was simple i just had to weld in a supplied 02 bung and i did exten the power wires to reach under then hood but its was cut and dry
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
20170310 163816
20170310 163948
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
they were a few feet short for reaching under the hood and i didnt want to run to the batt and have power 24/7 running to it which by the lenght seemed like it was set up for??? very strange!!!!
JCart
JCart
897
2,024
Kamloops, BC Canada.
Yes Jak!! Thanks for the pix and update! Question, so can you set up the AFR gauge temporarily, adjust the parameters where you want then take gauge off? Or does it stay attached to the system all the time? Why the need for an O2 bung could you not just use the stock location?
Thanks again,
j
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
no can not use the stock location because the system still uses the stock o2 sensore for when its in open loop and i belive you need to leave the gauge attached but i could be wrong
solrus
solrus
1,629
2,511
Montana
Did you find out if you still need to have OEM O2 sensor to keep or remove it and use provided by Dobeck? Thank you!
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
you still need the stock one attached and working
