P700 Dual batteries necessary?
P
Paintforsix
Arkansas
Couldn’t find this in the search, can anyone tell me if duel batteries are necessary? I’ve got a few leds and planning on a radio?
Reactions: TimG
68,407
No, it's not.
But several things to consider.
How long/often will you be using your radio/accessories with the engine off?
How afraid are you of the battery going dead?
And how often do u plan to use the winch?
A sence of security with a full primary battery is the main reason for dual batteries.
So to recap:
Keep the motor running when winching and limit accessory usage with engine off and there is no need for a second battery.
Some guys put a full size car battery under the seat.
Not a bad idea if you want to do that.
Reactions: TimG
P
Paintforsix
Arkansas
I don’t plan on running the radio very long with the engine off. I do plan on upgrading to a full size battery too.
Reactions: TimG
allgm1
allgm1
1,049
1,485
New Hampshire
Full size car battery is all I run, I like to keep it simple with fewer components to potentially fail.
Reactions: TimG
allgm1
allgm1
1,049
1,485
New Hampshire
Well a car size battery won't fit where the stock battery goes, so a mount had to be made to accommodate a larger battery, then once you have the battery mounted longer wires will be needed. I made my own mount ( I'd post pics but photo bucket is holding them captive) from 3/16 steel plate and went to my locally owned auto parts store for some custom made wires to get me where I wanted to go. Really the hardest part was the mount.
Reactions: joeymt33
jwfirebird
jwfirebird
927
1,446
western ny
seems like it works if you have a good pop up blocker and they have big ads on the pics now, must be they figured out no one was going to pay the stupid price
allgm1
allgm1
1,049
1,485
New Hampshire
I'll have to check, the last time I looked I could veiw my pics but they wouldn't let me copy the link address
Here’s a picture of the battery mount I Purchased from a company that is no longer in business.
02ebbb41b0f3c6a3c9d6ee261c4f9fc8
You can see the heat shield in the picture. That is probably important for the life of the battery to reduce some of the heat from the exhaust pipe
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
2 batteries isnt necessary but stock battery wont hold up and last long if you winch a moderate amount. i have a 4seater i put car battery in back behind seats inside bed extender with longer cables lets me do alot of things easier right there like not moving passenger when someone needs a jump. also airing up tires on my trailers and jeep are easier this way since i have a hi speed pump that uses alligator clips
Reactions: Paintforsix
