![Spadoo](/data/avatars/m/58/58380.jpg?1717130284)
Spadoo
Hello! First I want to apologize to everyone in advance as I know this topic has been posted many times before. My issue is that I am in no way an electrician nor someone who even understands electrical design. Yet, I am going to attempt to install a dual battery system this weekend on my new 2024 1000-5 Forest I recently purchased.
I have watched almost every Youtube video available and read through TONS of threads and discussions on the forum regarding this. There was SO MUCH information and more than one way to do this, so I decided to use bits and pieces from many of your system and create one that suites my needs. I just ask that anyone with experience take a quick look and let me know if what I came up will work. I am open to criticism and any and all suggestions. Thank you in advance!
One of the main goals I wanted to integrate into this system is the ON/OFF/ON rocker switch to have the ability to run the dual system with Key-On Power / OFF / Auxiliary Battery Only (when machine is off).
What I have purchased:
I have omitted most the grounding system to make the diagram less jumbled.
- Odessey PC925 Battery w/ "L" terminal adaptors
- True Battery Isolator Kit - Amazon.com
- Stinger 80 AMP Battery Isolator Relay - Amazon.com
- Red Wolf 100 AMP Disconnect - Amazon.com
- Honda Pioneer Key-on Power Harness
- Honda Pioneer Power ACC Pin for Key-On Power
- 10-Way 100 AMP Fuse Block - https://www.amazon.com/junction-box...tion-Automotive/dp/B075L6T1PP/?tag=sxsweb24-20
- 7 Pin DPDT Rocker Switch - https://www.amazon.com/Bandc-Marine-Rocker-Switch-Waterproof/dp/B00P7ZS5GE/?tag=sxsweb24-20
- Positive & Negative Bus Bars (Incase I need to integrate these into the system)
- Accessories to be added for now:
- 52" Light Bar (below windshield mount)
- Soundbar
- Rear Light Bar
As an Amazon Associate we earn from qualifying purchases.
