P1000 Dual Battery Diagram
Reddmann
32
61
This is my lowly attempt at showing my dual battery setup, for anyone that might need help with it. This is on a 2020 1000-5 Deluxe. I know it looks like a jumbled mess, but I thought I'd share. Maybe it'll help someone...
  • Dual Battery Diagram.pdf
Papaandhistoys
Papaandhistoys
134
227
Backwoods of northern Michigan
Great drawing, but I was wondering where your winch is plumbed in, unless you don’t have one.
Reactions: Reddmann
boilermaker72
boilermaker72
greensburg, Indiana
In the midst of installing my accessory power management system. I have used so much of the guidance from previous posts and it has been great to draw from.
I am having issues getting my dual volt meter installed correctly. Some background, I have the true dual isolator installed and working. I also have my stinger installed and am using a OTT switch to control my key acc. or switch it to be just have it on the second battery. all of that is working correctly.
I have the dual volt meter wired to each side of the isolator......what is everyone using for a keyed ground for the meter??
Thanks,
Shawn
TripleB
TripleB
12,178
104,232
Caryville, Tennessee
Thanks,
Shawn
Your tru isolator kit should have came with a relay that will turn the volt meter on with key on power.
Reactions: Reddmann
boilermaker72
boilermaker72
greensburg, Indiana
It did come with the relay.....I understood that if I am using a stinger that I do not have to install the relay??
If so how so I wire the meter into the loop with the stinger??
JoeyL
JoeyL
276
741
Houston
you can do that, but you will have to be careful where you hook up your positive volt meter leads. Aux battery will need to be after the stinger, and main battery will have to be with a key on power source
Reddmann
32
61
I have the stinger and I still used the relay. You can see how I wired it in that diagram and it works.
TripleB
TripleB
12,178
104,232
wh
what if you have a lighted rocker switch. it will run down the battery.
He's talking about the winches main power cables. Not anything to do with the rocker switch. Rocker switch will have key on power for the lights.
Reactions: Reddmann
