P1000 Dual Battery - Installed Under Seat
Manwell
Manwell
803
2,439
I decided to move my second battery under the drivers a seat to make room under the hood for the Bussmann fuse/relay panel. I left the isolator under the hood where it was originally mounted.
I tied the 140 amp breaker, isolator and cable coming from the battery together with a .250" SS terminal, $10 on Amazon and I just strapped it down with cable ties. I folded the cable coming from the second battery leaving enough that it will reach the first battery post. If something goes really sideways with the first battery, I can get power from the second battery from under the hood.
IMG 3368
Bundled and ran the cables, securing them inside protective loom. Spot taped the cables together and spot taped the loom as well. I ran it right next to the existing factory installed wire loom.
IMG 3363 IMG 3364
Secured the battery with a couple big wire ties and really cranked them down. I was originally planning on enclosing the whole battery, but decided that wasn't necessary.
IMG 3361
I will do something to cover the exposed terminals but it could be as simple as a flap of rubber, it will be something simple.
Manwell
Manwell
803
2,439
Great job. Nice and clean. This should work out well not only freeing up that space but lowering the center of gravity too.
Thanks!
Didn't even think about center of gravity! Maybe it will help offset the Hi-Lift I mounted on the upper rear ROPS bar!
Reactions: Delton and joeymt33
Manwell
Manwell
803
2,439
Just as an FYI, I ordered most of the stuff used for the battery install under the drivers seat from one of my favorite sources - Amazon!
Following are the links to the bits and pieces I used:
Cable:
https://www.amazon.com/gp/product/B0167K7DO2/?tag=sxsweb24-20
Ring Terminals:
https://www.amazon.com/gp/product/B005V9UW80/?tag=sxsweb24-20
Junction Block:
https://www.amazon.com/gp/product/B00ZZ06MFC/?tag=sxsweb24-20
Cable Ties:
https://www.amazon.com/gp/product/B00I0F1ABA/?tag=sxsweb24-20
The cable ties were not long enough and I had to use two together, worked fine. There are the very big ones you can get for HVAC duct, but they were like over $30 at Home Depot, got cheap and went this route. Also, the protective wire loom was purchased at the local auto parts store.
LandPioneer
LandPioneer
929
2,417
Lebanon TN
View attachment 25565 View attachment 25566
Great job @Manwell . Looks very clean and should work trouble free. I'm doing some wiring myself and hope mine turns out similar to yours!
Ridem32
Ridem32
938
848
Terry
Did not know that you could mount a battery laying on its side! But maybe the new gel type or lithium will be fine mounted on side
Reactions: dotman1
allgm1
allgm1
1,049
1,484
New Hampshire
Looks like you spent a lot of time securing the wiring and it looks great, but I can't figure out why you scimped on the battery mount. I'm sure if you just putt around on smooth roads that will be OK, but I don't think I'd be real comfortable with that set up. I used 2 pieces of 1/4"all thread on mine and I'm still a little concerned.
Manwell
Manwell
803
2,439
Maybe it's enough, maybe not... Felt pretty secure, but time will tell. I tugged on it big time and couldn't budge it. I will report back indeed after it sees some real world use...
K
Kennyjo
5
Ga
89D9A441 5530 46CE B626 DA0326F828DA 511B6602 B5A5 481F 9713 873DB480891F D8F2335B EE30 4B72 A04D B7A92E701071 CF6FE059 0BC1 49EF B6D0 9E42FD27FC19
K
Kennyjo
5
Ga
Have slide in the optima and wire it
