G
I have an issue and and I’m hoping this group can help.
I’m running a dual battery setup with a true battery isolator, stinger relay, 100 amp breaker, blue sea fuse block and a switch panel with a dual battery voltmeter.
Everything has been working fine. Running constant 13.9-14.1 volts on both batteries. I did a little riding yesterday and ended up getting pretty muddy. Nothing above top of tires. Got in a rainstorm driving home and washed it after that. Got up this morning and voltmeter shows main battery still at 13.9-14.1. Second battery is now showing 14.8-17 volts. So far I’m only running two lights and they work fine.
Thoughts on what might be my problem? Hoping just got something wet and it’ll fix itself when it’s good and dry.
