Does anyone have a picture of their Dual Battery setup? I bought my Pioneer 1000-5 slightly used, and there is a battery drain. I noticed it has a secondary AGM battery, and I tested it and it's dead. I figured it may be draining the primary battery. The secondary battery is wired to the primary battery only (with the black wire going through an isolator between the two batteries). None of the accessories are hooked to the second battery, and are all wired to the primary battery? I would assume that all accessories should be wired directly to the second battery, and the main battery should just have the primary hookup and the wires to the secondary battery and isolator?
