P1000 Dual Battery volt meter
Reddmann
32
61
I’ll be installing the True brand dual battery kit in the next few weeks. I’ve been searching for an answer to this question for a few days, but I’m still not sure how to wire up the volt meter. It says to connect the red wire to a switched ignition power source? Where is that? Do I need to cut a wire somewhere and splice it? Sorry if this is a crazy question, but I’m no electrician. Including a photo of instructions for reference. Thanks in advance for any help/advice.
DD1EABF0 03E0 43B6 87AE B5325A75C52D
russknight
russknight
1,910
7,507
Perry Florida
Yes.
You need to either cut and splice a key-on hot wire or pickup a connector like this that is plug-n-play.
Don't even try and splice anything, just go ahead and order this. I did and and it's worth every cent. I used it to energize two blocks so I have multiple connection points for key on and continuous hot.
Reddmann
32
61
russknight, I like the idea of plug and play. Can you show/tell me where to hook that up? Also, did you add the 2 blocks yourself? If so, do you have links to the blocks? Thanks!
Reactions: Lady01
Superthrill
667
1,557
North Carolina
I wires mine straight into the batteries. Yes itnia on all the time, but very little drain. I can look at a glance and see battery condition if i am playing the stereo or even when it is setting in the garage. No need to turn key on to read voltage.
Been on for over a week at a time between cranks and never drains the batteries.
Reddmann
32
61
Thanks! I went ahead and ordered the key on power harness. I was thinking it would be hard to install, since I'm really not an electrician, but there's actually an access door just below the 12V accessory plug, so that should make it pretty easy. Thanks again.
Reactions: Lady01
Hillbillytnt
Hillbillytnt
521
1,922
Ky
Sorry for old post reply, but should we need a relay for the daul monitor ..
The dual voltmeter gets its power from the two wires it’s measuring so the best way to shut it off is through the ground. The true kit provides a ground relay. Meaning it only provides a ground to the meter when it’s triggered by a key on or other controlled power source. Without the relay or switched ground the meter is lit all the time.
05Willys
05Willys
528
3,310
It is the same thing. The only difference is you connect the ground wire from your meter to be opened/closed instead of the power wire. Same concept different wire. In order for it to light up and be readable, you need a complete circuit from the battery to the meter (or what ever accessory you are powering), then back to the opposite post of the battery. You have 2 power feeds to the meter so it's easier to disrupt the ground side.
bumperm
bumperm
1,851
6,658
Gardnerville, NV
One side of the relay coil will be connect to ground, the other side will be connected to a key-on switched positive voltage source. When the key is on, the relay will be energized.
Ground (can be jumpered over, the same ground wire as you have going to one side of the relay coil above) is connected to a normally open (open when relay is de-energized) contact. The other normally open relay contact will provide the switched ground to the dual voltmeter ground terminal.
This switched ground may also be useful for "turning off" rocker switch illumination for those switches that get their power from an always on (not key on) power source, such as the AUX battery.
