P1000 DUNES DUNES DUNES
88dunerider
48
59
oregon
What do you think of the skat trak 27x11x12 , 8 paddle or 10 paddle hauler ?
Reactions: strongbuilt
strongbuilt
strongbuilt
260
606
If you can find them! They would work perfectly I assume. I don't know personally if a 12" rim would work on a pioneer or not.?
322,785
Standard models come with 12’s
Reactions: BWAF
88dunerider
48
59
oregon
what you guys think 10 paddle to much ? stay safe and go with 8 paddle?
strongbuilt
strongbuilt
260
606
Cant wait any longer
IMG 4195 IMG 4199 IMG 4200 IMG 4201 IMG 4203 IMG 4204
E
elkguide
3,377
7,964
Vermont
Just remember...... before you take off, you shouldn't start by saying,
"Hold my beer while I try this!"
Looking good!!!!!
322,785
Looking good!!!!!
Bulls***... that’s how every good story later after you heel up begins!
strongbuilt
strongbuilt
260
606
Thanks!! I'm really liking the way this girl looks, Really want to cut my roll cage down.... warranty would be void though if something were to ever happen. I want to find a stock roll cage so I have a spare to experiment with.. Any volunteers? hehe
Reactions: CumminsPusher
322,785
Careful there @CumminsPusher .
You're not as young as you once were and the "healing up" process takes a lot longer than it used to!!!!!
Are we talking about hangovers or crashing??
jonathannook
jonathannook
11
Quartzsite AZ
We have sand/dunes here. I don’t have any troubles in 2WD (not turf mode) and just lower the tire pressure. Do that and not keep blasting it or putting yourself in that position like @CumminsPusher said you’ll be fine. That clip is 4WD high BTW due to the hill. But most of the time in 2WD
How much can you lower the tire pressure without the worry of breaking the bead in sand dunes?
Reactions: Remington
115,789
That’s a good question. Depends on the tire and the wheel. If u have beadlocks you can go as low as you want. I usually did 8psi then again I had a Banshee then. With the Honda, it all depends on your tire/wheel package.
jonathannook
jonathannook
11
Quartzsite AZ
Just bought mine, so still have the factory stock tires. I'm going to try it at Glamis aired down, although not sure how low I can go, and see how it does before deciding on paddles, but something tells me that I 'will' need paddles ;)
