Easiest place to get "key on" power?
binfordw
131
10
I'm starting to wire my winch, and am not seeing an easy place to splice into a "key on" power source. Where did you guys tie into things at?
Reactions: ChadD
43,563
I used the $6 sub harness off of the power port under the hood.
You could also just use the scotchlocks on one of those wires as well.
Re: Easiest place to get "key on" power?
I created a buss off the battery that was controlled by a relay, I triggered the relay off the same wire Honda tells you to tie into for the factory aux panel.
It is included in the install instructions for the AUX panel.
Reactions: richd1963
wyo700
wyo700
413
210
I spliced into the wires that goes to the 12v plug. Really easy to get to. White wire is power.
Reactions: 1911Man
67,900
+1.
This is the easiest way. Wire is very accessible.
binfordw
131
10
Hondasxs said:
+1.
Ah, would have been easy, before I crammed the heater in there :D
I managed to get enough room on the fuse block to cut and splice into power.
hydrantman
I also used the 12V Plug in (White Wire Hot) I went to Home Depot and pick up some Splice Tap Connectors don't have to cut wires made this a simple operation just tape when done. Here put this number in the search on EBAY 271112154353 these will be easier just bought some. NO MORE CUTTING INVOLVED!!!
Reactions: MikeG and 1911Man
Slackjaw
Slackjaw
294
462
Durham NC
This one?
Reactions: ChadD
