Had put a couple responses in Warped Battery Box post without pictures.
Easy <> Quick Method
Run 1 Lead ( UN FUSED )<> 6 gauge or Heavier <> from the Battery Positive <> out the EXISTING in the Back of the Battery Box ( located near Top Center of the Battery ) as PICTUERD. P520
RUN this Pos. Lead to a Busbar ( Location Best suited to your build ) most do under hood connections. ( I do both
I put a Master SHUTOFF Switch in this 12V Pos.Lead <> ( located in the plastic Below Driver seat Behind Rt. leg along with a Busbar & then to another Busbar under the hood ) <
> Allows Separation of Start Battery & All acc. <> Plus EASE of adding acc..
Next run a Negitive Lead <> 6 gauge or Heavier <> to a SEPERATE BUSBAR. At or near the Pos. Busbar. ( PREFERED location to get Ground is from the Motor )
No more Messing around at the Battery Box.
All ADDED Accessories Should Be Cnnected & FUSED from this location.)
EPS
Winch
Battery Tender
2nd Batt. & Isolator
Music
Wiper & Washer
LED Lights <>Ft.
EPS
Winch
Battery Tender
Music
Wiper & Washer
LED Lights <>Ft.
