I just assumed it did. When I tested one at a def. dealer they said I had to have it on or it would not run correctly. That was back in July last year. Then when I pick this one up they had the seat belt hook and then seat on it to move it. It is a 2016.Looking good, what year is it? I don't think the 2016's had any kind of safety latch. The 2017's have a seatbelt safety system.
That red plug is the diagnostic port for the power steering I think.
Finally got her home. They added a winch, roof, window and plow. Now it's my turn. Added just a cross bag for now. Was going to disconnect the safety switch for seat belt. When I took the cover off there was nothing there. Never tried it before. The shop had the seat belt latched. Just assumed it had one. Looked under seat and there was a red plug with nothing plugged into it. Would that be the safety switch not hooked up.
View attachment 32349 View attachment 32350 View attachment 32351
This is the sticker on the light. It says 480v + or - 25w. Does that mean I would need a 45 amp fuse.
The wires don't seam to be that big. View attachment 35006
Ok. But what about the fuse. With a 40 amp relay does that mean I don't need a fuse. Sorry for asking but I'm not that up on elec.I recommend a 40 amp relay to power that size light.
But it's 500 watts!!??You need a 25-30 amp fuse on the relay and a 5-10amp fuse on the switch.
